Getting rid of water in fuel sensor - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-08-2013, 07:55 PM Thread Starter
My water in fuel sensor is bad in my truck and has been for about a year. It might be solid for a week then go off or just flash on and off a lot. I drain my bowl about every month anyways, does anyone know where I can buy a plug or what size the plug is for the truck? Thanks.
tucker0104 is offline
post #2 of 3 Old 06-09-2013, 12:09 AM
sgt dave's Avatar
Quoted: 3 Post(s)
i beleive its 1/8 npt thread for the plug
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 3 Old 06-09-2013, 07:58 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Note that the WIF sensor is made to also hold in the Fuel Heater pass-through device, so a plug may not work in that case. Also the WIF circuit contains both a sensor (on the bowl) and a switch (solid-state, cubed shaped device in the engine wiring harness on top of the motor driver's side towards the front). Might need to determine which part is failing first. Cheers!
Patrick Feeley is online now
