icp bad symptoms? - Ford Powerstroke Diesel Forum
post #1 of 80 Old 06-08-2013, 02:34 PM Thread Starter
icp bad symptoms?
Ok truck just got new fuel line new cps and now its runnin rough. Code came up for ICP low voltage....batteries are only a few months old would the ICP make it run rough enough it doesn't want to accelerate? Needing to find out if its my issues tired of the guessing game.
Thanks for any help guys
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #2 of 80 Old 06-08-2013, 03:15 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
easiest way to check it to unplug it. it will set a check engine light, but if it runs better than the ICP is your issue
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 80 Old 06-08-2013, 03:34 PM Thread Starter
Ok just went out to start it now won't start and is putting out white smoke......injectors?
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #4 of 80 Old 06-08-2013, 05:33 PM
the baconator
Quoted: 146 Post(s)
how's it cracking over, fast/slow, white smoke means it's getting fuel
post #5 of 80 Old 06-08-2013, 05:35 PM Thread Starter
Its cranking a little harder than normal and it sounds like injectors are knockin a bit when it almost starts up I'm starting to lean more towards loop or hpop
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #6 of 80 Old 06-08-2013, 06:11 PM Thread Starter
Anyone want to confirm my suspicions or tell me otherwise please
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #7 of 80 Old 06-08-2013, 09:05 PM
the baconator
Quoted: 146 Post(s)
do you have access to a scan tool or AE, that can measure HPOP and duty cycle? if the LPOP is bad you will have a hard time filling the reservoir and that is easy to check. you can also try pulling the IPR and cleaning that and replacing the O rings. also dieselsite sells rebuilt IPRs for $75
post #8 of 80 Old 06-09-2013, 04:20 AM
dr.deere's Avatar
Quoted: 19 Post(s)
Sounds more like what my 97 was doing when we put the motor it had a bad ipr and idm at that point. When lpop failed it wouldn't try to fire it smoke
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #9 of 80 Old 06-09-2013, 08:33 PM Thread Starter
Ok its trying to fire but nothing but white smoke it sounds so dang close to starting but it sounds if it would start it would be running rough as he//. What should be the first part to try replacing irp or ICP....ICP has oil on plug
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #10 of 80 Old 06-10-2013, 12:04 PM Thread Starter
Nothing guys really......I get better response in the chat thread lol
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
