International "blue" CPS replacement... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-08-2013, 03:03 PM Thread Starter
I've had this one in the glove box for a long time...
Improved Blue CPS for 7.3L Ford Powerstroke Diesel (bottom of page)
...and it claims to make the engine run smoother, quieter, better mileage etc.
So I'm going to install it today (or tomorrow, depending on replies ) but I need to know if I have to disconnect the battery before doing this?
Or there's some fuse that I should pull?
Has anyone tried out the International CPS and is it as good as they say?
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 11 Old 06-08-2013, 03:16 PM
66Bronco's Avatar
All you need is a 10mm wrench and 10 minutes.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 11 Old 06-08-2013, 04:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
No need to disconnect batteries, just make sure the truck is off when doing it, let us know your results
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 06-09-2013, 04:07 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
i have been running the "dark blue" cps in my dually for about 2 weeks or so... Seems to run good on it...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 11 Old 06-10-2013, 07:28 AM
nplote's Avatar
I have been wanting to get one of those myself. I am curious to see what difference yours makes. I've heard only good things so far. If you o to puredieselpower.com they have them there for 49.99$ and all the reviews are really good.
nplote is offline
post #6 of 11 Old 06-10-2013, 12:20 PM
Arcturus's Avatar
I bought the blue international at Dfuser for $40 shipping included. They also have the Ford CPM for $30 shipped.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #7 of 11 Old 06-10-2013, 01:04 PM
Quoted: 2 Post(s)
so does this sensor really make any differnce over the stock ford one ?
97 f250 4x4 ccsb
auto
typical exhaust /6637 intake/ chip
add a leaf leveling front
otherwise mostly stock
joshh77 is offline
post #8 of 11 Old 08-25-2013, 02:59 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
i just installed one on my truck two days ago.
i had the gray ford cps before.
i have noticed the miss and vibration at idle is gone. the motor runs much smoother.
cant say mpgs are up yet, but i feel the truck is running smoother and is quiter.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 11 Old 08-25-2013, 05:48 PM Thread Starter
Just got back from a rather intense pull through the Fraser Canyon...(26 ft Travel Trailer) and I must say, there seems to be "some" improvement over the stocker.
I was able to maintain at least 50 MPH on every hill, no matter how steep...although I was dropping a bit when I reached the Jackass Summit!
Overall, I calculated 16 MPG as the mileage...that's 2 MPG more than the same trip last year with a lighter trailer, so I guess this thing was worth the money!
YMMV
Qwazert is offline
post #10 of 11 Old 08-25-2013, 07:12 PM
Micko's Avatar
Quoted: 4 Post(s)
I run the gray International with purple o ring. Runs and shifts very nicely. I must say though, it runs even better after cleaning the fuel reg screen. I've had it for about a year.
Micko is offline
