Banjo bolt fuel lines. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-07-2013, 11:00 AM Thread Starter
jjones96's Avatar
I'm working on a friends f-superduty. And the fuel lines with the banjo bolts are leaking. Does anyone know if someone makes braided steel lines to replace the stock steel ones
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #2 of 4 Old 06-07-2013, 02:31 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Hose-Man makes all kinds of steel braided line. I also have Performance shops here that will take any steel line or rubber line and make it a braided line. Hydraulic, Fuel, Brake, anything with less than 5000psi.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 06-07-2013, 03:18 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Here's the factory part:
Fuel Line Assembly, Metal (supply from fuel pump banjo to heads, 49-state)
(Ford) F4TZ-9A564-A
List is $74.43, and AutoNation Ford White Bear Lake Parts (previously Tousley Ford) has it for $49.13. Cheers!
Patrick Feeley is offline
post #4 of 4 Old 06-07-2013, 03:55 PM Thread Starter
jjones96's Avatar
Thank my buddie just wanted to upgrade to braided steel
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
