radio problem - Ford Powerstroke Diesel Forum
Old 03-17-2008, 04:35 AM
Send a message via AIM to 814_wescott Send a message via Yahoo to 814_wescott
radio problem
My radio was stock till i got ahold of it lol. I thought i can take the stock out and put in a cd player but now im in a pinch the stoke one is hanging there. I was wondering if it was bolted in in the back some how i cant image it is in there that good i got the face of it tore off it lol. need help
Old 03-17-2008, 04:49 AM
Powerstroke Techie
Send a message via Yahoo to gbear
From the service manual on a 95 which will be the same type mount here is the instructions. I place of the tool, I used two small flat pieces of metal.
Good Luck
Jim
Removal
1. Disconnect the battery ground cable.
2. Remove the four mounting bracket screws.
3. Insert Radio Removing Tools T87P-19061-A, one on each side of the radio, into the access holes in bezel until a click is heard. Apply an outward side pressure to release the locking tangs and slide the radio from the dash.
4. Disconnect the radio power lead, antenna lead-in cable and the speaker lead wires at the radio.
5. Remove the support bracket from the back of the radio.
6. To disengage Radio Removing Tool T87P-19061-A, depress the locking tangs on side of the radio while applying slight inward pressure on the tool and pulling tool out of access holes.
Old 03-17-2008, 04:55 AM
ok
Yeah i figured thats what those 4 little holes where for but now the radio is hanging in the dash it wont slide out it acts like somthing is still hooked all the way in the back of the radio.
Old 03-17-2008, 05:19 AM
Infidel
You can use a coat hangar to get it out. Cut the coat hangar into pieces and make a couple of "U" shaped pieces. Insert into those holes on the radio pull the "U" shaped pieces away from the radio. You might have to do one side at a time and work it out, but there aren't any other bolts / connectors holding it in. Except for the wiring harness plugged into the back of the unit.
Craig
Old 03-18-2008, 11:01 AM
BIG TRUCK, SMALL DRIVER
There is a slide that holds the back of the radio. When you get the retaining clips released, you may have to wiggle the radio back and forth to get it to slide. You can also use small nails to release the clips, but it is worth the price to get a set of removal tools from Walmart.
