Your typical no start thread - Ford Powerstroke Diesel Forum
post #1 of 29 Old 06-06-2013, 12:29 PM Thread Starter
I went to start it this morning, and the lights came on like usual, glow plug light on and off as normal, and nothing when I turn the key. A relay (fuel pump relay as it turns out) kept clicking for a minute and the hazard lights on the outside blinked with them.
Tell me what I'm doing wrong. I'm no electrical expert, so I've been reading around online and testing/replacing parts trying to eliminate the possibilities from most to least likely. I put on new starter and glow plug relays, starter, and fuel pump relay. the fuel pump relay in the under hood fuse box kept clicking and the hazard lights blinking even after all this.
It's not what I've been wanting to do on my day off, especially since I had to cancel a kayaking run with some friends because of it
-Austin
2006 Ranger Sport
1996 F-250 XLT ECLB 4x4
SOLD
1986 F-350 XLT RCLB 4x4
SOLD
acprimus631C is offline
post #2 of 29 Old 06-06-2013, 02:04 PM Thread Starter
All the fuses are good.
-Austin
2006 Ranger Sport
SOLD
SOLD
post #3 of 29 Old 06-06-2013, 06:26 PM
rolsmojave3's Avatar
Have you tried jumping the Solenoid on the passenger side firewall. Whats you battery voltage at?
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #4 of 29 Old 06-06-2013, 07:05 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Sounds like low voltage to me.
You don't have an electric fuel pump either.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 29 Old 06-07-2013, 02:32 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Unless you have Efuel you have a mechanical fuel pump in the engine valley, so i'm not sure what "fuel pump" relay you replaced. I would check batts and make sure voltage is correct. If all is good, then as mentioned above jump the starter solenoid on the pass fender. If it turns over then that is your issue.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #6 of 29 Old 06-07-2013, 10:07 AM Thread Starter
The solenoid on the fender was the first thing tested and the starter tried turning over so I replaced it. I didn't even think to test the batteries since everything in the cab was going on as it should. I gotta borrow a tester later and see if jumping the batteries gets it started.
Seth, I took the relay that was clicking to Napa and they told me that's what it was The original pump is still in there.
Thanks guys, I'll let you know how it turns out.
-Austin
2006 Ranger Sport
SOLD
SOLD
post #7 of 29 Old 06-08-2013, 07:49 AM
jesilvas's Avatar
Quoted: 3 Post(s)
You heard the relay buzzing and clicking so it wasn't working like it should. That usually means low volts.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 29 Old 06-08-2013, 08:36 AM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
THIS.... and i bet it was your IDM relay. they click when you have weak batteries
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #9 of 29 Old 06-08-2013, 11:37 AM Thread Starter
I tested my batteries with my buddy's Snap On and waffle iron testers. They read in the low 11s so I had them tested at Napa and got the same results. They decided to replace them under warranty as they were from last year so I can't complain I put them in and still no start unless I jump the solenoid. Still clicking and blinking as before.
Which is the IDM relay?
-Austin
2006 Ranger Sport
SOLD
SOLD
post #10 of 29 Old 06-09-2013, 07:01 PM Thread Starter
Bump. Still can't figure it out.
-Austin
2006 Ranger Sport
SOLD
SOLD
