Sensor in factory air box .... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-06-2013, 09:29 AM Thread Starter
ChiefRocka's Avatar
I was checking out the situation with the install of the WIX.
Of course there was K&N in there ....
Should this sensor be installed at the end of the 6637 ?
Not a big deal to do so, just ask'n
ID:	121386   Click image for larger version
ID:	121394   Click image for larger version
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 9 Old 06-06-2013, 09:34 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Some do, some don't, mine is just laying next to the filter, just don't let it rest on metal tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 06-06-2013, 09:39 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
2x. That is the IAT. Just reads how hot the inlet air is and runs comparisons across the oils temp, coolant temp, and the MAP sensor. I read some people taking it off and nothing happens.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 9 Old 06-06-2013, 10:39 AM Thread Starter
ChiefRocka's Avatar
Got ya .... thanks guys
John
post #5 of 9 Old 06-06-2013, 12:18 PM
Zip tie it to the fender. Stays out of the way of everything.
-Austin
1996 F-250 XLT ECLB 4x4 w/E4OD 119k and counting
6637 intake
Diamond Eye 4" turbo-back exhaust
rebuilt tranny
1998 Buick Regal GS 149k
parts runner with blown head gasket
acprimus631C is offline
post #6 of 9 Old 06-06-2013, 01:01 PM Thread Starter
ChiefRocka's Avatar
Will do .... for now I did this.
(I ran out of 4" mandrel bends)
Pipe was a little loose fit so I cut a piece to sleeve it...then welded seam.
Press fit into filter for now, tight.
I will redo the entire thing once more pipe comes in....
ID:	121570   Click image for larger version
ID:	121578   Click image for larger version
John
post #7 of 9 Old 06-06-2013, 01:06 PM Thread Starter
ChiefRocka's Avatar
Temporary .....
ID:	121594   Click image for larger version
John
post #8 of 9 Old 06-06-2013, 01:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You going to clamp it at all?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 06-06-2013, 02:03 PM Thread Starter
ChiefRocka's Avatar
Absolutely ...
Once I get more pipe, I plan on making some mounts to support filter off of fenderwell.
John
