97 7.3 stalling VERY RANDOMLY!!??!!?? - Ford Powerstroke Diesel Forum
Old 03-16-2008, 04:19 PM
Send a message via AIM to kx592
Exclamation 97 7.3 stalling VERY RANDOMLY!!??!!??
Hey guys, just picked up a 97 7.3 PS for 5800$ w. 170K on the dash . She runs great but in low rpm's at stop signs and going real slow in reverse she will stall. It is really annoying and im wondering what I can do to fix it. Would a dirty fuel filter cause this?
Old 03-16-2008, 04:23 PM
ADMIN AND TECH
very doubtful its the fuel filter , that doesnt cause as many problems as people think, i would guess the torque converter is locking up and causing the engine to stall, that would be the most common problem for your concern , make sure oil is full and in good shape also
Old 03-16-2008, 05:55 PM
So how would I go about checking the torque converter and would all i need to do is change the fluids?
Old 03-16-2008, 06:00 PM
ADMIN AND TECH
you cant really just check the torque conveter , its one of those things that you just have to have a feel for, the best way to start with diag on this problem is start by pulling codes , see if there are any codes , if no codes its possible to be tc problem, if it is , a new converter would have to be installed , and service trans good, if you know a good trans shop, get there opinion, dont let them just sell you one though , like i say , get some diag done
Old 03-16-2008, 09:10 PM
stalling on these is usually caused by a faulty cam position sensor and this will not alwayws throw a code, it was recalled by ford 95% chance this is your problem
