2wd zf-5 to 4x4 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-05-2013, 08:03 PM Thread Starter
2wd zf-5 to 4x4
I found a 1992 F-450 that has a zf-5 with the e-brake on it for sale, and I'm needing the transmission to go into my 1994 F-350 4x4. I know the 4x2 and 4x4 transmissions are different, but I was wondering if the 2wd transmission can be modified to go into my 4x4 truck.
Regards,
sgg93
sgg93 is offline
post #2 of 3 Old 06-05-2013, 08:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Remove the e brake put the transfer case on it and done
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 06-05-2013, 08:47 PM
Quoted: 82 Post(s)
Exactly what Kris said. The Zf-5 case with the E-brake bolted to the back of it is a 4x4 transmission.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
