Can a newer 5sp auto be put in OBS? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-05-2013, 07:35 AM Thread Starter
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Question Can a newer 5sp auto be put in OBS?
I was wondering if a newer 5sp auto can be retro fitted into a OBS truck? I figure it would cost less to build one to take power and get good mileage on the freeway due to the overdrive gear? Has anyone heard of this kind of swap?
Jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #2 of 6 Old 06-05-2013, 07:53 AM
superduty4x4's Avatar
No because of the computer programming required to run one.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 6 Old 06-05-2013, 08:33 AM Thread Starter
Quoted: 3 Post(s)
5sp auto
Dang. I was hoping there could be a stand alone unit that put that trans in the truck.
post #4 of 6 Old 06-05-2013, 09:19 AM Thread Starter
Quoted: 3 Post(s)
Possible stand alone controller from PCS
I did some checking around at destoked and they offer a stand alone controller for the 5r110 trans. I've sent them a email, if this will work that is defiantly a option when my trans eventually goes out. I'll post what I find out.
Jim
post #5 of 6 Old 06-05-2013, 09:45 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
anything can be done, with enough time and money. and like you found out with a stand alone controller i think it could be done. you may need a manual PCM for the engine. and i think the stand alone controllers for the trans run $1K+
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 6 Old 06-05-2013, 01:28 PM
JSchuricht's Avatar
There are a few running an Allison trans behind their 7.3. Destroked makes the adapter.
JSchuricht is offline
