Changing out windshield washer hoses? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By madpogue
post #1 of 6 Old 06-04-2013, 10:17 AM Thread Starter
Arcturus's Avatar
What am I missing here? How do I access the hoses in my 1996 PSD? It disappears into the firewall and I have no idea how to access the connections to the nozzle. I may as well get new nozzles while I'm at it.
I figure if I can get the nozzles out from above, I can attach the new hoses with a barb and snake them through. Is this how it is done? Though there is probably a y connection somewhere in the firewall to get to the drivers side nozzle.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #2 of 6 Old 06-04-2013, 10:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pull the wiper arms and remove the cowl
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 06-04-2013, 11:42 AM Thread Starter
Arcturus's Avatar
Thanks! I knew it had to be something simple. Even as simple as me.
While I'm in there, is there anything else I may want to change out?
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 6 Old 06-04-2013, 11:46 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Not sure what all else is in there I've swapped the nozzles to those led ones once when I was like 14 years old lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 06-21-2013, 08:32 PM Thread Starter
Arcturus's Avatar
Next question. I removed all the visible screws on the shroud
from the firewall and on top. How do I remove the chrome molding from around the window? It also seems like a sealant or double sided tape is holding the shroud tight on the firewall side. Is this case or am I missing something?
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #6 of 6 Old 06-21-2013, 09:21 PM
Quoted: 58 Post(s)
You should be able to remove the cowl with the windshield moulding in place. I forget exactly how; perhaps slide it forward as you go up. You may have to raise the hood for part of it and lower it for part of it. It's sorta like the pedal box; you curse at it, finagle it this way and that, and eventually you get it loose, wondering "how'd I do that?"
You might encounter some rust on the sheet metal of the cab under the cowl; this would be a good time to prime/paint it.
pwrstrktoy likes this.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
pwrstrktoy (10-09-2015)
