Power Steering Pump. - Ford Powerstroke Diesel Forum
Old 03-15-2008, 11:59 AM
Need instructions on how to remove and replace my power steering pump. Also can the pulley be taken off with a puller and a new one installed while the pump itself is on the engine? TIA
Old 03-15-2008, 02:47 PM
BIG TRUCK, SMALL DRIVER
You need a PS pulley puller. It is a little long, but you may be able to get it in there.
Old 03-15-2008, 03:01 PM
ADMIN AND TECH
take the lines loose from the pump, drop the belt, remove the alternator, take the 4 bolts loose that holds the bracket , and take it off the truck, ive found that is the fastest and easiest way to get pulley off and on, do have to have a puller and installer to swap the pulley
Old 03-15-2008, 03:55 PM
Thanks fellows, I just bought the pump. The pulley comes Tue. and with your reply info I can change it myself. Tx again.
Old 03-16-2008, 05:48 AM
On a 97 It doesn`t look as if you need to pull the alternator.
