Are the fuel tanks properly vented from the factory ? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-04-2013, 07:01 AM Thread Starter
ChiefRocka's Avatar
Every time I fill up, it seems I have to trickle the fuel in to get full tanks.
You can forget about a semi fill station will the high speed, big arse nozzels.
I remember a while back (before I owned my truck) I noticed a guy with an OBS, with both drivers side wheels parked on ramps while fueling.
My '06 UtiltyBody F-350 had similar tendencies.
Wondering if there is a fix for this ??
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 14 Old 06-04-2013, 07:52 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
There are some fixes for this (with varying degrees of success) in the forums. Maybe search on Fast Fill Mod or something like that. Do plenty of research before you start hacking things up! Tranfer Flow used to sell aftermarket filler necks to take care of the issue, but they are/were pretty pricey. You also could give Dale Isley @ Tymar a call as he used to sell a kit to help with the issue. There are plenty of folks that throw a couple of 4x4 chunks in the bed to drive up on when filling. Cheers!
Patrick Feeley is offline
post #3 of 14 Old 06-04-2013, 08:06 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Ive never had that issue, When the nozzle stops my tank is full. I can't even add more if i wanted too. But that seems to happen on my rear tank. My front tank is new. The rear tanks is from the factory.
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 14 Old 06-04-2013, 08:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You need the filler necks from a cab & chassis model, although on my dads cab & chassis he drives on 6x6 wedges to keep it from spitting the fuel back out he can pump so easily, my dually I have zero issues it's amazing, but the f250 I got you have to have the pump at the perfect angle, the perfect depth in the filler neck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 14 Old 06-04-2013, 08:22 AM
boozinag's Avatar
I have the same issue. You can also hold the pump sideways.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #6 of 14 Old 06-04-2013, 09:48 AM Thread Starter
ChiefRocka's Avatar
I know about different pump nozzle positions.
On the '06 ... pump #14 at this Valero station, with the nozzle upside down ... was golden !!
I will search, then check it out once I pull the bed off for a chassis detail...
I'm sure I will come up with something ....
John
post #7 of 14 Old 06-04-2013, 12:24 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Have this trouble with my f250 both tanks have been replaced I think my issue is the sleeves inside filler neck got twisted putting it back together
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #8 of 14 Old 06-04-2013, 12:33 PM
66Bronco's Avatar
Look up something called the Hutch Mod. Essentially you drop the tank to gut the vent on top of the tank. Over time the vent gets clogged with dirt/bugs/junk and the air in the tank cant bleed as fast as the incoming fuel. The increased vapor pressure in the tank is what shuts the pump off.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #9 of 14 Old 06-04-2013, 03:50 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
On my cab & chassis Superduty, it fills poorly also. Maybe because it was a Cali model? Friggin' infuriating.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #10 of 14 Old 06-05-2013, 05:51 AM Thread Starter
ChiefRocka's Avatar
Originally Posted by gaspipe View Post
Maybe because it was a Cali model ......
Hey, you watch your mouth !!
John
