Heavy Towing - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-15-2008, 05:49 AM Thread Starter
sk3322's Avatar
Heavy Towing
When I purchased my truck, the guy before me did a lot of heavy towing. What parts of the truck does that exactly wear and tear?
1997 7.3 F250 A/T, AFE Stage 2 intake, 3" DP to 4'' stright piped exhaust , pyro-boost-trans, leveled on 33's
sk3322 is offline
post #2 of 6 Old 03-15-2008, 06:22 AM
96Ford7.3's Avatar
The Back Axle
1996 F350 Crew Cab
Gauges pyrometer, tranny, boost
4" Turbo Back into Dual 6" stacks
SCT Tuner
Stage 2 injectors single shots
Fass fuel system
Coming soon: High pressure oil system, new tunes, bigger injectors, and Built Tranny
96Ford7.3 is offline
post #3 of 6 Old 03-15-2008, 03:54 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
The more you work the truck, the more it will wear. Everything from the frame to the engine will wear more. These trucks are designed to handle it, so hook it up
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 6 Old 03-15-2008, 04:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
as long as the truck is driving fine , i wouldnt be concerned about any of it , depending on how much weight he towed and was he pulling a tag along trailer or fifth wheel, if a fifth wheel was pulled , may want to just have the rear end fluid changed and maybe the bearings checked , i wouldnt sweat it to much they are built to handle it
ITS STOCK
SCUFFY828 is offline
post #5 of 6 Old 03-15-2008, 04:16 PM
sldghamr's Avatar
my first concern would be the tranny.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #6 of 6 Old 03-15-2008, 07:47 PM Thread Starter
sk3322's Avatar
the suspension just seems really tight and I have to replace the fuel injection pump and the front axle. The belt squeeks a little but other than that the truck drives fine.
sk3322 is offline
