Drop of coolant on bottom of oil filter... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-02-2013, 09:07 PM Thread Starter
ChiefRocka's Avatar
The other day when I was under the truck wrestling the stock down pipe, I notice a drop of coolant coming off the bottom of the oil filter.
Tomorrow, I will be back on the truck to finish exhaust, then Ill trace the leak ....
Wondering where could a coolant leak in this location be coming from, or running from to this spot ?
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 9 Old 06-02-2013, 11:48 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
Oil cooler o rings?
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #3 of 9 Old 06-02-2013, 11:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
On a semi related note, my coolant is going missing not dripping anywhere, but it's going somewhere, oil is fine tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 9 Old 06-03-2013, 12:01 AM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
Kris, you may have some injector cup or oring issues?
~Bruce~
gaspipe is offline
post #5 of 9 Old 06-03-2013, 12:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I did notice a couple bubbles on my oil dipstick, however my cyl contribution test fails cyl 7 as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 9 Old 06-03-2013, 03:15 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i would guess the oil cooler as well. it is the cylinder right in front and slightly higher thenthe oil filter
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 9 Old 06-03-2013, 03:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I will have to check that, what other symptoms come from that failing?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 9 Old 06-10-2013, 01:17 PM
Quoted: 3 Post(s)
Bad o-rings in the oil cooler can put some oil in the coolant or, less likely, coolant in the oil.
Over the past year, I had been losing coolant, but I could not find where it was going. I looked everywhere, even with a flashlight. No joy.
Finally, it seemed to me I "might" see a bit of moisture near the oil filter on the engine block, meaning perhaps the oil cooler is leaking from the gasket on the engine there. So, I got a new gasket and o-rings, pulled the cooler, and found my 17-year-old gasket and o-rings looked perfect! I installed the new gasket and o-rings. No improvement, still losing coolant.
Losing patience too, I finally put some Bars in my coolant (a quality stop-leak for radiators), and it scared my water pump into finally fessing up. It began pi$$ing coolant out its weep hole within a week.
A new water pump installed, and my coolant stays where it should.
Airstreamer67 is offline
post #9 of 9 Old 06-10-2013, 01:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But where did it go?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
