Tranny Temp. help - Ford Powerstroke Diesel Forum
post #1 of 57 Old 06-02-2013, 04:32 PM Thread Starter
Quoted: 4 Post(s)
Question Tranny Temp. help
Hello all, I left Phoenix two days ago towing my 36' 5th wheel heading to Oregon. I took Carefree hwy to 93 and then over to I-40. I'm in Kingman now and not too sure if I'm going to Oregon. I had a lot of trouble crossing the smaller hills and the bigger ones are still in front of me. I have a 95 F 350 duelly. Upgrades are bully dog cold air intake, new injectors (8), Bellowed uppipe kit, 4" diamond eye turbo back with 3" down pipe, rebuilt E40D tranny with all heavy duty parts, biggest tranny cooler w/o fan made. Going from Phoenix to Kingman my tranny temp hit 200 and sometimes as high as 210. Once I was going up a grade and my "overdrive on" light started blinking and I pulled over asap and just let it idle fow about 5 minutes before shuting down for a while. That stopped the blinking but when it's hot it seems to be idleing not on all cylinders. I don't know how to explain it but it just didn't sound right to me. Since sitting here in an RV park since Friday It sounds like it always does again but it isn't hot from towing either. My 5th wheel weights 12500. Is the trailer just too heavy for this truck or what?
timlsalem is offline
post #2 of 57 Old 06-02-2013, 05:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you down shifting out of od to keep the boost up? 210 is high but I would have kept going, you need to find out what codes the trans is throwing as well, do you have egt/boost gauges too?
Arizona is just unlucky for me
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 57 Old 06-02-2013, 05:11 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Were you going up the hill with the TC locked or unlocked?
If it seems like you're not on all cylinders, might have a cracked flywheel?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 57 Old 06-02-2013, 05:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
He has an auto
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 57 Old 06-02-2013, 06:32 PM Thread Starter
Quoted: 4 Post(s)
351fifty:I don't have a boost gauge but I do take it out of OD to keep the RPMs up. The two gauges I have are a tranny temp and an EGT. I have no way to get codes on the tranny but I think it would throw out hot tranny code. The ambient temp outside was in the 90's also. Average tranny temp on this trip so far was 192. Wonder if I should put an electronic fan on my cooler?
post #6 of 57 Old 06-02-2013, 06:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
As long as your moving the tranny fluid cooler should be fine, a fan won't hurt either tho, and more than likely the trans is throwing an over heat code, have you checked the fluid level? As far as the not firing on all cylenders thing goes you should check the uvch, and there are a couple other things to check, but with out a code reader and diagnostic tool to run tests it's kind of hard,
Kingman az is rite before the ca state line rite?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 57 Old 06-02-2013, 08:08 PM Thread Starter
Quoted: 4 Post(s)
what is a uvch? The level was checked before I left Phoenix but I haven't checked it lately. I'll do that tomarrow. ya, kingman is about 65 miles from the ca border. I was planning on going through vegas and up NV to Reno. The climb that way is gradual till Reno. I'm not sure it isn't firing on all cylinders. It just didn't sound right to me while I was sitting on the side of the road cooling it off. When I started it up again it seemed to be fine and ideling normal. I did get some Lucus injector cleaner today to add to the fuel. Also, I could have gotten a bad load of fuel when I filled up at circle K in Phoenix.
post #8 of 57 Old 06-02-2013, 08:47 PM
Gaius's Avatar
Quoted: 40 Post(s)
I wouldn't be too worried about 210 degrees, when it hits 250 I would be worried. However, it really shouldn't get that hot. You need to get the codes ran. I'd drive it to a tranny shop and have them run it. It could be the TC or clutch packs slipping that it raising temps.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #9 of 57 Old 06-02-2013, 08:58 PM
nohsp4u's Avatar
Not to hyjack the post but, got a question. When you asked, if the OP was running with the TC locked or unlocked, is that another way of asking if he has OD engaged or disengaged?
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #10 of 57 Old 06-02-2013, 09:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Under valve cover harness, but check the fluids and make sure trans fluid don't smell burnt as well, and a bad load of fuel would also through the water in fuel light or fuel filter light, but like also said have the codes read
No, the trans unlocked produces a lot more heat as opposed to unlock, only real way to tell without adding a light to inform is just by feel pretty much
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
