Pressurizing intake - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-02-2013, 02:52 PM Thread Starter
svranger25's Avatar
Pressurizing intake
hi guys i was pulling my fifth wheel over the weekend and could barely hit 10 psi something has to change about that or mpg is gonna suck on my upcoming 200 mile trip, i checked exhaust system but dont see any signs of leaks, now i am trying to pressurize the intake, what i've done is hook air compressor to the spot where my boost gauge taps in, and capped the intake any other places i have to stop cause wouldnt the air just flow through open valves in the engine? any help would be appreciated
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #2 of 8 Old 06-02-2013, 03:40 PM Thread Starter
svranger25's Avatar
Also is there a gasket between turbo and intake pipe under the clamp?
-Brandon-
post #3 of 8 Old 06-02-2013, 04:33 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
there should be an oring in there. there is a little grove around the turbo outlet where it sits
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 8 Old 06-02-2013, 04:45 PM Thread Starter
svranger25's Avatar
yep thats what i figured trying to find a good place to order it now, also looking for a y pipe, if i can find one cheap i'll throw it on and see how the boost is w/o the IC if nothing changes i can start on exhaust, anyone know good places to get the o ring or the y pipe?
-Brandon-
post #5 of 8 Old 06-02-2013, 04:53 PM
the baconator
Quoted: 143 Post(s)
where is the stock y pipe? did yours not come with one? best place to get teh oring is ford. there are $3 or less and in stock at least they were at my local dealer 2 ish years ago.
post #6 of 8 Old 06-02-2013, 05:12 PM Thread Starter
svranger25's Avatar
previous owner probably has it, i guess i'm yard searching
-Brandon-
post #7 of 8 Old 06-02-2013, 05:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The stock y from turbo to the heads?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 8 Old 06-02-2013, 06:57 PM Thread Starter
svranger25's Avatar
yep that one, what years are the same part?
-Brandon-
