Clunking sound in front is finally gone! - Ford Powerstroke Diesel Forum
Old 03-13-2008, 09:55 PM
I had a clunking sound in the front end. It was especially noticeable at slow speeds and when I turned. I found that the stabilizer shock was bad, even though it felt tight when I jerked on it. I found the problem by placing some grease on the stabilizer shock shaft and then when I drove the truck discovered that the sound was then almost non existant. A new stabilizer shock solved the problem!
