Swapping my '95 injectors with '97 model split-shots... - Ford Powerstroke Diesel Forum
post #1 of 29 Old 03-13-2008, 04:12 PM Thread Starter
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
I have a '95 PSD with 169k on it. It recently started acting up, and we think its the injector o-rings.
Anyway, while we were in there (me and dad, mainly dad) I was figuring i could get a set of the injectors like that came in the '97-up trucks. I'm pretty sure they switched them to 120cc split-shots that year. (Correct me if i'm wrong about the split-shots.)
Anyway if i stumbled up on a motor that year that had those injectors, could i just swap them out and keep trucking, or is there anything i need to change, mod?
thanks for any help!
Typical cummins owner.
taylorking is offline
post #2 of 29 Old 03-13-2008, 04:29 PM
Cynic
Dirk's Avatar
Splits fire differently. You would need a 97 pcm or custom programming for your engine to run correctly.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #3 of 29 Old 03-13-2008, 04:38 PM Thread Starter
Too cool for school
taylorking's Avatar
alright so just need to swap pcm's? They splits should smoke some more also, without having to go DIY 160ccs
post #4 of 29 Old 03-13-2008, 04:43 PM
Cynic
Dirk's Avatar
I was giving general info. I HIGHLY recommend you stick with your AA codes and do the DIY kit. Your 15* HPOP will thank you for it later. The pump will run AB's fine for the moment.. but if you have a weak IPR, you will know soon enough. Especially if you chip the truck.
Single shots will also give you better fuel mileage.
Dirk is offline
post #5 of 29 Old 03-13-2008, 05:28 PM
Big K's Avatar
Not to mention the Cali Fuel system with the different fuel damper
It is really a waste of time and money to put Cali Injectors in.
Just get DIY160CC Single Shots and be done
Kevin "Big K" Neal
President
North Texas Power Stroke Association
972-768-7252
Big K is offline
post #6 of 29 Old 03-14-2008, 04:09 PM
Tsgs69400's Avatar
Does anybody make 140cc injectors by chance as stg 1's or are those the tranny savers?
Thad
2008 f-350 CCSB 4x4 6.4 Lariat Spartan Tuned, MBRP Duals, S&B intake, egr delete, ccv delete,custom coolant bypass, RF amps, Infinity Component Spkrs, Pioneer Shallow Sub, 13.9sec best
1996 f-250 Extended cab Short bed 4x4 7.3 5-spd, D60, Diamond Eye4" duals, DP Tuner, Stg 1 Injectors, DIY Intake, Custom Regulated Return Fuel System, Adrenaline,billet ww,Comp 910 springs, D66 Turbo, 6.0 Intercooler, SD rear springs,Custom trac bars, Truetrac diff.
Tsgs69400 is offline
post #7 of 29 Old 03-14-2008, 04:16 PM
sledhed99's Avatar
i have had early 99 split shots in my 96 for 2 years on a weak hpop. so far so good but obviously it is not the choice way to go but it works for me. Also a little quiter
Early 99 F350 Xcab-LB Dually
07 Front end conversion
Ts 6 bank w/ custom tunes by BTS
Auto meter Casserly hybrids
Bts regulated return fuel system
Modified Hypermax H2e
BTS 4R100 transmission 6.0 trans cooler
97 obs cab and chassis
Stage 2's 38r T500
Electric fuel south bend
sledhed99 is offline
post #8 of 29 Old 03-14-2008, 06:15 PM
Cynic
Dirk's Avatar
stage 1 and stage 2 singles are both 160cc. The stage 2 have a larger nozzle and the stage 1 uses the stocker. The 140cc is the AD injector. If you are already running AB's, AD is a nice drop in (CHEAP) upgrade. You'll need a chip to see any gains.
Dirk is offline
post #9 of 29 Old 03-15-2008, 06:55 AM
I did the DIY 160CC injectors in January. Got them from Jim Rose. Really liking it. I just wasn't that hard to do. Also, the truck starts much better now having changed out the seals in the process. So far my mileage has kinda sucked, but I'm still having trouble keeping my foot out of it.
Fullcrew '96 F350 CC DRW, diy stage 1's, FPR shim, 3.55 gears, diy intake, Valair SM flywheel, SCT 1705, Pyro and boost guages, diy ebpv exhaust brake, 40-20-40 seating, diy 4" side oiler, dead kitty, transfer case(from '93 F250)
Fullcrew is offline
post #10 of 29 Old 03-15-2008, 07:52 AM Thread Starter
Too cool for school
taylorking's Avatar
I'm sure they didnt put the split-shots in just the Cali Trucks. My dads friend has a 97 F-350 DRW that he gets my dad to do maintenance on. That truck idles smoother and is quieter than my '95, or any '95 in this case. Something was different in those trucks
