Compression questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-01-2013, 04:41 PM Thread Starter
cuzzdogg's Avatar
What is the normal range for compression test on a '94 7.3?
And are the blocks the same in a '94 and a '99?
Sent from AutoGuide.com App
cuzzdogg is offline
post #2 of 8 Old 06-01-2013, 05:39 PM
toad's Avatar
Quoted: 23 Post(s)
I was told the ford spec is between 400-425. This will drop depending on your elevation. I just checked mine and it was 350 right on the dot. I am about 4500 feet. I think the blocks are the same between the 7.3s
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #3 of 8 Old 06-01-2013, 05:49 PM Thread Starter
cuzzdogg's Avatar
Thanks
cuzzdogg is offline
post #4 of 8 Old 06-01-2013, 09:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The bottom end is identical from 94.5-03, with e the exception of the rods in 2000-03 being pmr
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 8 Old 07-25-2013, 12:43 PM Thread Starter
cuzzdogg's Avatar
How long should u crank the truck to register the psi. Or just continue to crank until the psi levels out?
cuzzdogg is offline
post #6 of 8 Old 07-25-2013, 02:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
When I did a compression test on a gasser it was 3 turns iirc
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 8 Old 07-26-2013, 10:53 AM Thread Starter
cuzzdogg's Avatar
iirc?
cuzzdogg is offline
post #8 of 8 Old 07-26-2013, 11:02 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If I recall correctly
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
