Ttb pitman arm - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-31-2013, 07:38 PM Thread Starter
Ttb pitman arm
I have a 96 eclb f250 and I have my steering box out due to a nasty crack. Well the pitman arm will not come free even with a blue wrench, so new pitman arm it is. Now I know if you do a d60 you should do a f350 pitman arm but what about on a ttb? In the future (probably a year plus) I'm going to swap a d60 in. Should I put the 350 one on to save money in the future? I know it won't help me now with turning. I'm also running a 33x12.5 tire.
Impulse138 is offline
post #2 of 5 Old 06-01-2013, 05:12 AM
Quoted: 2 Post(s)
it will make it steer quicker and unless the pump is in perfect condition may be a little hard to turn at idle
97 f250 4x4 ccsb
auto
typical exhaust /6637 intake/ chip
add a leaf leveling front
otherwise mostly stock
joshh77 is offline
post #3 of 5 Old 06-01-2013, 10:37 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I still have a 250 pitman arm in my sas'd f250
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 06-01-2013, 03:04 PM
Chop's Avatar
The 250 arm can work with the dana 60 but the turning ratio is reduced ,this is well documented . The 350 arm is a tad longer and obviously for a reason .
I changed to the 350 arm a year later after the axle change and it improved the turning radius as I expected but what I didn't expect was the steering wheel alignment was about 60 degrees out .The 60 axle is simple to align per say and all I did was turn the drag link adjuster till the steering was centered and this job was finished .
I would think a 350 arm on a ttb is too much "geometry " ,and may just bite you where you don't want it to
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #5 of 5 Old 06-01-2013, 09:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine has a terrible turning radius I must add, I could'nt bust a u turn with 4 lanes and a median to save my life without having to use reverse
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
