Downpipe R&R ... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-31-2013, 05:57 PM Thread Starter
ChiefRocka's Avatar
Downpipe R&R ...
(auto tranny)
Looks like I'm gonna cut it half to get it out.
Will the dipstick tube have to be modified for the new one ?
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 4 Old 05-31-2013, 06:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What I did was cut the down pipe while still attached to turbo maybe 3-4" back where it starts to turn, unbolt it at the cat, get a big bar (cheater pipe) twist the stock down pipe so it's flat to the firewall or close, pry against it on the firewall in a few places, get under truck and wiggle it outta there
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-31-2013, 06:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Btw did not remove a single thing or loosen anything other than the engine lift point back there
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #4 of 4 Old 05-31-2013, 07:57 PM Thread Starter
ChiefRocka's Avatar
Cool ...
Unbolted it from the turbo, then realized I had to bolt back up to firm it up for the cut.
My plan is to mock up slip fit the entire exhaust with stainless Torqtite clamps ... and if I dont need to use truck right away, have the entire exhaust jethot coated.
Really like the finish. Use it alot on customers rides...
Here is the 3" I did on my father-n-laws Z069/LS7 powered '69 Stingray:
John
