OBS FPR SHIM?
Ok im a newbie to the forum and just bought my truck a month ago pics of the truck are under the introductions forum "new truck" thread anyways liked I have been warned I am getting addicted to this site and have been searching and reading for hours instead of studying for my stats test like I should be doing instead, I came across a write up on the FPR Shim, and wanted to do it to my truck but had a quick question. I don't have any bbs but I reload shotgun shells and have alot of steel shot would a #2 steel shot work or should I just go to walmart and get a package of bb's? and should I get a gauge to install too and see if the pressure is right or will I be fine just putting in the bb and reinstall the brass plug? I have a 96 with a K&N intake banks 1.0 housing, banks intercooler and a 3.5 inch straight piped exhaust would doing this mod be effective and worth it?
I also found a write up on the IDM mod would this be a worth it mod for me too? I am pretty mechanically inclined and thought myself to weld, fix any problem with my old car, as well as fix alot of stuff that breaks down around the house so doing stuff myself doesn't scare me. thanks for any advice! |
I just did the bb mod a couple weeks ago. It helped my truck's idle smooth out. I've got an Edge tuner and after setting up the tune, it idled rough. I did the same to a buddy's truck and he saw no difference. One thing to watch for is there is a dimple on the plug. You need to make sure that dimple is located in the end of the spring when reinstalling the plug. When I did mine, I was careless when I reinstalled the plug and bent the spring. I had over 120 psi showing on the gauge when I started the truck. I took it back apart, tweeked the spring back into shape and reinstalled correctly and had 70-75 psi.
hi and welcome. the bb mod is easy to do and worth it. the only downfall is that you will have many bbs left over just hit walmart and spend the 2 bucks on a pack of bbs. another thing to is make sure you clean your screen located in the fuel bowl. this being cloged can and will affect this mod yet alone your trucks performance and milage. and yes get a guage to monitor incase of spikes. I installed a guage on my piller that has an eltrical sending unit. hope this helps
every truck is different so check ur pressure first, you may not even need to shim it. as for the K&N toss it in the trash and get something better. AFE, or a lot of people go with a Tymar DIY kit it 's probably the cheapest
Do you have a 4" tube for the K&N?
If so... the AFE isn't the only option - you also have the Napa filter. |
yea it is the 4 inch tube, which one is better (filters more) and which one is better (performance) price is a factor but I want what is best for my truck don't want to have to replace anything because of a bad filter which is what I hear about the K&N (it lets in dirt/dust or something like that?)
also does anybody have any suggestions on what and where to get a fuel pressure gauge im going to try Napa tomorrow I need a liquid one right?
liquid yes you will want one that read 100+ psi the part number depending on what AFE you want is
51-10792 thats the stage II pro dry 54-10792 that is the one I am running and lastly 75-10792 thats with th pro 7 filter advanced FLOW engineering : Product Search v3. |
