solenoid pack replacment - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-30-2013, 11:24 PM Thread Starter
vick97psd's Avatar
OK after talking to a few trans techs come to the conclusion that the solenoids pack needs to be replaced I have a new pack but I read on another forum a while back that there is a spring and check ball held in place by the pack but can't find that thread now. So in my search I haven't come across anyone saying anything about this so I'm just looking for a lil help need someone to tell me once and for all if there is a check ball or not, and if so where does it go so I can get it in the right location when reassembling trying to do this later today as I have a trip to go on Saturday and don't want neck snapping shifts thanks in advance for any and all help
97 OBS F-350 cclb 4x4 7.3L CCV mod w/filter, 6637 intake, 3" DP, 4" straight exhaust, Banks I/C, Glow Shift boost, pyro, trans, fuel pressure. gauges, diy e-fuel, Racer X eagle t/c, Derale cooler pan, inline spin-on trans filter, IDP bellowed up-pipes
Soon to come- HPOP, Racer X valve body, Swamps injectors, Swmaps 6pos chip, Swamps IDM, haven't decided on turbo yet
2010 Supercrew FX2 Wifes ride
vick97psd is offline
post #2 of 10 Old 05-31-2013, 04:48 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
when i replaced the one in my old truck i didn't see any ball, spring
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 10 Old 05-31-2013, 05:39 AM Thread Starter
vick97psd's Avatar
Cool I'm liking the sound of that. And a lil off topic I really like your white truck in your signature
post #4 of 10 Old 05-31-2013, 08:49 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
There is one steel check ball actuated by a spring and eight rubber check balls. The steel one is in the lower left corner of the brain assembly.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 10 Old 05-31-2013, 09:14 AM Thread Starter
vick97psd's Avatar
Yes but is that when you drop solenoid pack or the whole valve body cause looking at the pic you posted all the rubber balls for sure are under the valve body the solenoid pack is no where near that big
post #6 of 10 Old 05-31-2013, 09:20 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
The Solenoid pack is directly below the Steel Check ball. Removing the pack exposes the check ball as stated in the other thread.
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 10 Old 05-31-2013, 09:34 AM Thread Starter
vick97psd's Avatar
OK so I need to watch for the check ball and spring to fall out when I pull the pack. What is the best way to keep the spring and check ball in while installing the new pack and do you have a better pic of where it goes
post #8 of 10 Old 05-31-2013, 09:42 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Honestly I have not done a solenoid pack only on a E4OD. I've always pulled trannies to have gravity on my side. Terry, JJ, and Elmo would know this better than I.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 10 Old 05-31-2013, 01:43 PM
the baconator
Quoted: 141 Post(s)
did not know that. good thing mine didn't fall out (or maybe it was never in there )
as for the white truck that was the one i swap packs on and it has moved on down the road.
post #10 of 10 Old 05-31-2013, 01:52 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
In some turbo trannies the checkball was held in with a simple washer that lightly pressed in (kinda like the late model LPO check ball). Ford manual says almost nothing about the steel ball except to not lose it.
Matt
'97
-Stage II trans.
BigFuel is offline
