Tranny dipstick leak - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-30-2013, 08:18 PM Thread Starter
I have searched and searched but have not found the answer. My tranny dipstick is leaking at the base as it enters the transmission. How do I fix this? Does it just pull straight out and then I replace the o ring?
fowllivin is offline
post #2 of 13 Old 05-30-2013, 09:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yes it does...
Afaik
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 05-30-2013, 09:47 PM
Wannabitawerm's Avatar
There is probably a bolt somewhere on the side that holds it as well but yeah, o-ring at the base of the tube.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #4 of 13 Old 05-30-2013, 09:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
There is one on the back of the head keeping it secure as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 13 Old 05-31-2013, 01:19 AM
JSchuricht's Avatar
If it's leaking at the base, you are going to have some fun trying to fix it. The tube is in two sections, the lower section is pressed into the trans. If it's leaking between the upper and lower section then it's just a oring.
JSchuricht is offline
post #6 of 13 Old 05-31-2013, 05:38 PM Thread Starter
I double checked and it is leaking at the base not at the connection between the two pieces. Do I have to drop the pan?
post #7 of 13 Old 05-31-2013, 07:15 PM
JSchuricht's Avatar
You will need to drop the pan and the rest of the transmission or pull the cab. The good news is the tool you need is fairly cheap.
The pic shows the trans standing on it's tail.
post #8 of 13 Old 05-31-2013, 10:08 PM Thread Starter
Wow not the news I was hoping for. Thanks for the replies. I will see how it goes.
post #9 of 13 Old 06-01-2013, 12:17 PM Thread Starter
Anybody ever put some ultra grey around the base?
post #10 of 13 Old 06-11-2013, 09:00 PM
did you fix it yet?
2001 F350 4wd CC LB in all white
2003 X 2wd Eddie Bauer
Griff350 is offline
