Truck Starts sometimes and sometimes wont - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-30-2013, 05:20 PM Thread Starter
Ok, I did the 10k mod a while back, and after doing it, I tried to wire up a switch so I could turn it off and on. Well while getting the switch done, the switch didnt work and it had a bad loping sound. So I took everything back off and put it back to stock. Then I replaced the ICP sensor. It didnt fix anything. If I let the truck sit for a while it will start. But if I drive it then shut it off then try to start it again, it wont start. Please let me know what you think it could be. Thanks
Djones21 is offline
post #2 of 5 Old 05-30-2013, 06:36 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Make sure the pins of the ICP connector are making good contact (they sometimes get opened up too much if you put the 10k leads into the connector ... and when you take it off you get bad/intermittent contact). You could try too squeeze them down a bit or get a new pigtail:
ICP Sensor Connector (repair connector with 12” pigtails for ICP, EOT, EBP sensors)
(Ford) 5C3Z-12224-A
(International) 2501105C1
Cheers!
Patrick Feeley is offline
post #3 of 5 Old 05-31-2013, 05:55 AM Thread Starter
i bought a new pigtail and sensor. Still messing up
Djones21 is offline
post #4 of 5 Old 05-31-2013, 11:00 AM
Quoted: 13 Post(s)
If it is not starting only when warm, maybe pull the IPR and inspect the o-rings (I guess if you're that far in, might as well replace them). Cheers!
post #5 of 5 Old 06-01-2013, 10:22 AM
You might have an injector o-ring problem.
To diagnose, put a high pressure gauge on the braided
Steel lines running to each head, one at a time, and crank the
engine. Gauge should read between 1500-3000 psi. It takes at least 500psi
to start. The reading on the left line will be the pressure for the right head, and the right
for the left.
A shot of either on the air filter might make it spin fast enough to start after its warm.
hayesplumbing is offline
