4th guage ? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 05-30-2013, 11:03 AM Thread Starter
ChiefRocka's Avatar
4th guage ?
In the market for some guages ... thinking about a quad set-up.
Beside the obvious 3 most important, should I get a forth ?
Would would I want to monitor .... Spare tire pressure ??
Also, boost range thru 60 I'm assuming is enough sweep.
How about pyro 1200, 1500 ??
Keeping in mind mods will come later ...
Thanks !
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 33 Old 05-30-2013, 11:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I have boost, trans, egt (1600), and hpop, I would suggest the instead of hpop get the aero force interceptor or make a chip switch mount
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 33 Old 05-30-2013, 11:15 AM
Phillipjon's Avatar
Quoted: 76 Post(s)
I would get the 40 psi boost gauge.
Phillipjon is offline
post #4 of 33 Old 05-30-2013, 11:36 AM
I have an hpop as a forth, neat to have, im not sure it is necessary though, it connects to the engine harness so you could get an aero force interceptor like 351 said and still read hpop. I have a 60psi boost gauge as well. 35 or 40 is fine for most trucks id imagine . definitely get more than 1200 for egt.
96 f350xlt cclb 4x4 7.3
96 f-superduty cc cnc, project truck
Parts accumulated: zf6, dana super 60 and s110 out of an 05 f450, most of a tan interior with remote entry dash and a bunch of other miscellaneous
stuff.
coreylasalle is offline
post #5 of 33 Old 05-30-2013, 11:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I'm topping my 35 psi boost already, and reading hpop psi is pointless without know duty cycle IMHO, yes I have a pointless hpop gauge
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 33 Old 05-30-2013, 12:10 PM Thread Starter
ChiefRocka's Avatar
Well I kinda wanna have low pressure guages, so they max out like all the guages in the fast n furious movies ....
No, but seriously ...
Aero Force Interceptor ??
Definately like the switch mount idea !
John
post #7 of 33 Old 05-30-2013, 12:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 33 Old 05-30-2013, 12:17 PM Thread Starter
ChiefRocka's Avatar
OK, just looked up Aero ... definately one to have
Watched a U-tube video on it.
Wondering if every monitored function is compatiable with the OBS PS ??
John
post #9 of 33 Old 05-30-2013, 12:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Aside from boost and egt it reads everything, although you can buy the adapters to read boost and egt, but it won't read higher then the PCM will iirc, I like the sweep of my other gauges tho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 33 Old 05-30-2013, 01:52 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
It will read boost from the MAP sensor.
To the OP...A good fourth gauge to have is fuel pressure.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
