How to determine gear ratio?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-29-2013, 09:21 AM Thread Starter
Psd171's Avatar
What is the best way to find out my gear ratio 96 f-250?
Psd171 is offline
post #2 of 6 Old 05-29-2013, 09:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Look for the axle code on the door tag
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 05-29-2013, 10:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
If it is still stock Kris
Lift one rear tire and using chalk draw a line straight down from the tire to the ground. Next draw a line from the u-joint in front of the pinion shaft to pinion neck of the pumpkin housing in the axle housing. So at this point the line on the tire and the line on the d-shaft all line up to their reference lines on the ground and pumpkin. Put the tranny in neutral and spin the tire one full rotation while you count how many times the d-shaft line crosses the pumpkin line. 3.5 times you have a 3.55, 3 3/4 times your have a 3.73, just over 4 times and you have a 4.10 (and so on). If the one tire does not want to spin than you also have a limited slip in the rear and will have to lift both rear tires off the ground to continue.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 6 Old 05-29-2013, 10:44 AM
If you do it with just one tire(open diff) ya gotta divide by two. The driveshaft will spin 8 1/4ish times to be a 4.11. If it's a posi/limited slip, then both tires one rev and count the driveshaft without the dividing.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #5 of 6 Old 06-03-2013, 04:16 PM Thread Starter
Psd171's Avatar
okay thanks. I knew it was't stock they said it was different but didn't know what they were
Psd171 is offline
post #6 of 6 Old 06-03-2013, 04:37 PM
Unless your clutches are worn out then it will still spin when you have limited slip.
tucker0104 is offline
