Boost & EGT numbers - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-29-2013, 07:11 AM Thread Starter
PhilMac's Avatar
Boost & EGT numbers
Wanted to get some opinions. I have recently chipped my truck (see sig) and installed guages. This weekend I towed my camper about 35 miles and its just under 7k. This is the first thing I have towed since I got the chip. There was one long grade that I had my chip set in 80 tow that my egt's got up to 1200 before I let off. Is this normal? I am worried what will happen if I hitch up 10k or more. Also, what is everyone getting for boost numbers? On the 100 hp setting I am maxed out at about 22psi and 12-14psi stock. I was thinking if my boost #'s were low it would cause a higher egt. It seems to me I should be a little higher. I do get a little black smoke at wot on 100hp or 80hp. I do have a slight engine miss between 1200-1900 rpms. Prolly an injector just havent had time to get it checked. Just wanted to see if anyone had any thoughts
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
PhilMac is offline
post #2 of 8 Old 05-29-2013, 08:26 AM
jjones96's Avatar
U can peg ur get gauge in a stock truck fairly easily as well as for numbers I don't let mine get over 1250. And for boost I'm not in a race anywhere when hooked to a trailer and I hit 16 psi of boost regularly. Without a trailer connected making a good pull it makes 26 to 28 psi of boost
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #3 of 8 Old 05-29-2013, 08:36 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Non Cali trucks still had 90cc singles in '97. 16 PSI stock was pretty normal in these trucks. Tuned people have seen up to 23-4+ PSI but to get the most from your towing consider to start saving up for stage 1's and a 1.0 housing plus a Intercooler. If you are still thinking that your numbers are low check all the exhaust pre-turbo for loose bolts and soot (exhaust leaks) and look into the turbo for excessive oil. Also check all you boots and all the way around your plenums for a pushed out gasket (all boost leak spots). Next disassemble the FPR and clean the screen. This is probably your hiccup while accelerating.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 8 Old 05-29-2013, 03:31 PM Thread Starter
PhilMac's Avatar
Cleaned the screen this afternoon and wow was that thing dirty. It was clogged to the point to that it was holding fuel back. As soon as I removed it a few ounces of fuel spilled out. took it for a short drive and I wasn't getting any missing during accel. Still getting the black smoke during wot on the 80 or 100. is this normal? I have read that you shouldnt see smoke until you upgrade injectors. It doesn't bother me I just want to know it's being caused by a problem rather than normal operation. Thanks
btw after I cleaned it I pegged out the boost at 25 psi
360,000+ miles
South Bend Stage 1
Boost & EGT Gauge
DIY 6637
PhilMac is offline
post #5 of 8 Old 05-29-2013, 03:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
yes a little black smoke is going to be normal even with stock sticks, your just not going to get a whole lot
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 8 Old 05-29-2013, 07:45 PM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
Glad you got your issue figured out. A clogged screen will definitely cause issues when it comes to efficient and smooth running.
A little puff of black smoke is normal until the turbo lights and the boost builds. It does not seem like you have any boost leaks though, since 25psi is an acceptable number.
If you ever have any questions about your tuning, feel free to contact me or anyone else here at DP-Tuner. We would be happy to help you out.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 8 Old 05-30-2013, 01:31 PM Thread Starter
PhilMac's Avatar
Awesome. I'm sure one day ill upgrade injectors but pretty happy with everything now. Hopefully the screen clean will help mpgs as well.
Also, Very happy with the chip from dp tuner!
360,000+ miles
South Bend Stage 1
Boost & EGT Gauge
DIY 6637
PhilMac is offline
post #8 of 8 Old 05-30-2013, 02:03 PM
Quoted: 66 Post(s)
Yeah, a good working fuel system helps in every aspect.
Glad you are happy with the tunes!
DP-Tuner
Like us on
Justin Bochmann
