1995 F250 7.3L 4x4 for towing 5th wheel help - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-29-2013, 07:52 AM Thread Starter
Cwilson1's Avatar
I am new to the forum and new to the diesel and towing world. I ended up going with an F250 7.3 powerstroke with 126,000 miles because of the engines reputation. I will be towing a 34ft 10,000lb 5th wheel. I know I need to upgrade the trans cooler and change out all the fluids and filters.
What I dont know is if I should chip it and if so what chip? Or any other mods that would be benificial.
Also any other recomendations and advice towards towing and prolonging the life of the truck will much appreciated.
thanks
Cwilson1 is offline
post #2 of 21 Old 05-29-2013, 08:13 AM
quicknick106z's Avatar
intercooler............. intake........
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #3 of 21 Old 05-29-2013, 08:24 AM Thread Starter
Cwilson1's Avatar
Which ones if any in particular?
Cwilson1 is offline
post #4 of 21 Old 05-29-2013, 08:28 AM
Intake you can order a tymar or a DIY 6637. Open up the exhaust with a turbo back I bought a diamond eye with no cats. Tues a t6 with custom tunes and gauges .
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #5 of 21 Old 05-29-2013, 09:04 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Auto? Get one of these:
Dieselsite / Tranny Cooler
Like the others said free the intake and exhaust. Intercoolers are great. I have a chip with Beans tunes and another with TW tunes. I like the towing power and shifting with the TW tunes better but it is smokier than the Beans tunes. Probably not going to be an issue with your stock injectors.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 21 Old 05-29-2013, 10:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Search DIY intercooler, it's with an e99 spider and can be made much cheaper than the off the shelf units, requires custom pipes and a lil fab work and a couple holes being made but I can't wait to intercool my second truck too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 21 Old 05-29-2013, 10:48 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
The one you just sold?
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 21 Old 05-29-2013, 11:04 AM
Phillipjon's Avatar
Quoted: 76 Post(s)
lol
lol lol lol lol
Phillipjon is offline
post #9 of 21 Old 05-29-2013, 11:16 AM
Undead Member
gaspipe's Avatar
Quoted: 6 Post(s)
If you're staying with the original 90cc single shot injectors, the 1.0 turbine works very well too with the aforementioned mods.
~Bruce~
'95 F250 4x4 ECLB 296k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3/5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite exl trans filter, Autometer, 180w LED bar
gaspipe is offline
post #10 of 21 Old 05-29-2013, 12:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They want to check it out tomorrow, if they dot pick it up it will be intercooled, I have to mod things lol, and if it sells then I will just intercool my dads truck unless I pick up another lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
