I have a 01 f350 with 7.3 It has 140,000 miles on it. It start missing and finally would not start. I have replaced the electric fuel pump and filter and cleaned out the tank and lines. Truck will start now but is still missing. I took it to a buddy of mine and ran a buzz test. It says #1 and #3 cylinder misfire. I put in 2 new injectors and still missing. Sometimes the buzz test says test pass and sometimes #1 and #3 and sometimes 1,3,5,7 misfire. I have changed out both computers and tried a new wiring harness for the injectors. I'm trying to check the wiring to the computer now. Should I just buy a new harness or could it be something else. Please Help I need the old girl @ 100%
man you just put a lot of money into your truck. try the CPS sensor did you do the recall yet. thats akk it might be
If you've swapped injectors and it's still missing, it's got to be electrical. Start with the under-valve cover wire harness (looks like you did), then the actuall valve cover gasket (the plugs go bad), then IDM & PCM (looks like you did). If that doesn't work, trace the wires. Got to be a pinched or broken wire in the harness.
Good luck. |
