Need suggestions on how to tow my 6.0 with my 7.3 - Ford Powerstroke Diesel Forum
post #1 of 20 Old 05-27-2013, 06:24 PM Thread Starter
7.3 on 40s's Avatar
Picked up a side project a month ago. 2005 F350 4x4 Ext. Cab with a 6.0 Diesel. Doesnt run (of course). Moving my family 300 miles south at the end of this week. Figured i would have had time to get the truck running but i have been to busy. I now need to bring the 6.0 with me. Id imagine the truck full of fuel weighs somewhere around 6500. Either of my 7.3s will tow it just fine but im lost as to how to tow the truck. I have a 24 foot enclosed trailer but it can only hold cars, bikes, and cargo. Uhaul dolly width isnt enough. Uhaul auto transport weight limit is just over 5k lbs. I think im in need of an oversized dolly or an equipment trailer. Going to give Hertz a call tom. What would you all suggest???
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #2 of 20 Old 05-27-2013, 06:27 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Sounds to me like you need a good tow rope and a buddy with nothing else to do....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 20 Old 05-27-2013, 06:27 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
I'd get an over sized dolly if you can find one and just yank the rear drive shaft.
dhanna6powerstroke is offline
post #4 of 20 Old 05-27-2013, 06:30 PM Thread Starter
7.3 on 40s's Avatar
No state troopers and id try the rope hahahaha
I really hope i dont have to end up buying an equipment trailer. Has anyone ever rented heavy duty trailers from Hertz??
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #5 of 20 Old 05-27-2013, 06:33 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I just wouldn't tell uhaul/hertz what it was that you plan to haul and just haul it.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 20 Old 05-27-2013, 06:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Tow bars, drop the drive shaft you will be fine, I got my bars for $75 with the lights
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 20 Old 05-27-2013, 06:36 PM Thread Starter
7.3 on 40s's Avatar
I was thinking the same thing about telling them something different but uhaul is out of the pic because they dont offer anything that can hold the weight.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #8 of 20 Old 05-27-2013, 06:39 PM Thread Starter
7.3 on 40s's Avatar
351 where did you get tow bars from??? Also what is the reason for dropping the D shaft? Heard that forever and have done it but does anyone know the real reason? I thought it was because the trans isnt turning to lubricate the bearing in the tail shaft.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #9 of 20 Old 05-27-2013, 06:48 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Wouldn't just popin the tcase into neutral do about the same thing?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 20 Old 05-27-2013, 06:57 PM Thread Starter
7.3 on 40s's Avatar
I would imagine putting the T case in neutral would allow you to not remove the driveshafts. On the 05 its electrical switch selection. Cant remember off the top of my head if there is an N position. Doing a little researc
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
