brake lights not working? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-27-2013, 03:27 PM Thread Starter
quicknick106z's Avatar
my brake light wire melted under the dash??? why?
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #2 of 6 Old 05-27-2013, 05:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It got knicked and grounded when power went through it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 05-29-2013, 09:53 AM Thread Starter
how do i fix it. its burnt up and goes up to a big thing of wire's
post #4 of 6 Old 05-29-2013, 10:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Can you see how far up the harness the wires are melted? All the way or just a section? Best way to fix is to cut out the affected wire and solder in new wires back to the switch.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 6 Old 05-29-2013, 11:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
^^ this is how to fix
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 05-30-2013, 06:02 AM Thread Starter
thanks guys
