97 start up rpm jump - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-27-2013, 11:29 AM Thread Starter
natemoses13's Avatar
Hey guys,
So I'm looking at this 97 powerstroke crew cab 2wd auto with 165k miles. It's in decent shape and the seller is not asking very much for it at all. When I showed up, he had it running and warmed up which I don't like cause it makes me think he's hiding something. Everything seems fine with it. It runs well and drives well so I'm mentally ready to buy and I ask him if I can shut it off and start it up. He says go ahead but the batteries aren't very good so I'm not sure if it will start. You can tell the batteries aren't very strong, but it starts fairly quickly. Immediately there is a type of lope but its not a good sounding lope. It will go from 350 to 800 rpms and bounce back and forth for a while and in order to even it out, you have to hold the accelerator for a few seconds. The owner said this never happened to him (I think he was lying) and he said its probably because of the weak batteries (is this possible since once it is started it should be running in its own?). Am I looking at bad injectors, a weak hpop, a bad idm or cps, or is it possible that a weak battery means weak glow plugs? The battery gauge on the dash jumps with the rpms.
I would appreciate any help you guys can offer.
E99 F350 crew cab dually flatbed. 2wd 6-speed. Boost and egt gauges. 6637 intake. Superchips flashpaq.
L99 F350 crew cab dually flatbed. 2wd Auto. Billet TC & aux cooler. 6637 intake. Superchips flashpaq.
natemoses13 is offline
post #2 of 11 Old 05-27-2013, 12:14 PM
sldghamr's Avatar
I had the same problem w/ my 96er. the ICP sensor was the cause for me.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 11 Old 05-27-2013, 12:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Many things can cause a lope on start up, check the uvch as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 05-28-2013, 08:44 AM Thread Starter
I will check this stuff out, but overall it's not a big deal (normally)?
post #5 of 11 Old 05-28-2013, 09:32 AM
Quoted: 54 Post(s)
Try starting it in Neutral.
madpogue is offline
post #6 of 11 Old 05-30-2013, 08:56 PM Thread Starter
I plan on buying it tomorrow. Hope the fix is simple. I'll try the neutral thing but it's an auto.
post #7 of 11 Old 05-30-2013, 10:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That's why he said it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 11 Old 05-30-2013, 11:43 PM
Quoted: 5 Post(s)
Unplug the icp sensor. If it idles smoothly, it's the problem.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #9 of 11 Old 05-30-2013, 11:47 PM
Quoted: 54 Post(s)
That's the point. Automatic trucks are known to have this problem, when the PCM doesn't properly sense that the truck is in Park. Sometimes starting it in neutral makes it start normally. This would suggest a neutral switch that's out of adjustment.
madpogue is offline
post #10 of 11 Old 05-31-2013, 02:56 AM Thread Starter
Ah. Thank you for explaining it, I am still new to obs and even 7.3's in general.
