Programming key fob - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-27-2013, 11:09 AM Thread Starter
Programming key fob
Need to reprogram my key fobs. Do you guys know the proper ford procedure for our trucks?
Thanks,
Nathan
1993 Black Cobra
1996 Mystic Cobra
1997 F-250hd ccsb 7.3
1997 F-250hd eclb 7.3
1999 Electric Green Cobra (11.75 at 116 N/A)
1999 Black 4v Whipple Lightning
2000 Cobra R #282
2003 F-250 7.3
2004 Black Mach 1 (10.39 at 132)
1997F-250HD is offline
post #2 of 2 Old 05-27-2013, 11:30 AM
NOTE: The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module, the remote entry receiver module is located in the LH side of the lower instrument panel to the right of the steering column, just above the driver's right foot area). All doors should lock then unlock. Remove shorting pin.
Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
Key off. All doors should lock then unlock.
Check operation.
Atem2144 is offline
