Door hinge problems - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-26-2013, 12:48 PM Thread Starter
mksnipe's Avatar
Door hinge problems
So I was replacing my hinge pins but I have dropped the backing plate for the hinge if anyone has done this and would be willing to share any tips it would be much appreciated.
1995 F350 CCLB
purchased 05/01/2013
160/30 powerstruck injectors
TS6 chip
Custom intake
MBRP 3" DP & 4" exhaust
E - fuel
Transgo HD2 shift kit
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #2 of 5 Old 05-26-2013, 05:34 PM Thread Starter
mksnipe's Avatar
Ok after much headache and cursing I got if fished back into place. In case this happens to any one else I had cut out a small portion on the bottom of the truck where it had fallen I could see it in a factory hole just had to widen it. Then I had to fish a piece of 550 cord through the bolt hole all the way to the bottom, then tie off the backplate and pull it from the bottom all the way back up into place. Then try to get it back into its slot on the body. A complete nightmare what started as a 1 hour job turned into about 5. Needless to say the next set I end up doing the hinge will not be coming off.
1995 F350 CCLB
TS6 chip
Custom intake
E - fuel
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #3 of 5 Old 06-01-2013, 12:01 PM
Quoted: 4 Post(s)
Thanks for the testimony! It will help others for sure.
If I ever get the urge to replace the hinges, your experience will ring a bell.
Airstreamer67 is offline
post #4 of 5 Old 06-01-2013, 10:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've replaced a couple hinges but have yet to drop them in there, glad you got it figured out bro, be sure to primer/paint the widened area to prevent rust
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 06-01-2013, 10:11 PM Thread Starter
mksnipe's Avatar
POR 15 is the best
1995 F350 CCLB
TS6 chip
Custom intake
E - fuel
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
