On the issue of blowby - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-25-2013, 08:49 AM Thread Starter
My truck appears to have a decent amount of blowby. There is a steady column of smoke rising out of the dipstick tube when the truck is at idle. I took it in to the steelership recently and asked them to run a check and access the overall health of my engine. They said that the crank case pressure test yielded a result of only 1psi.
Spec. is 4 psi. max. So it seems that I'm not too bad off there. They said overall it was in good shape.....(but sometimes I wonder about those guys)
My question is, how much smoking is normal? I have 212,xxx on her. Not a lot really. I'm interested in hearing others experience with blowby vs. crank case pressure.
So if my rings don't appear to be so worn, where is all the smoke coming from? Can someone recommend a product that would clean out any soot and gunk that might be causing the problem?
Thanks,
Mcstiggs
Mcstiggens is offline
post #2 of 5 Old 05-25-2013, 08:51 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Motor honey, all mine smoke, it's just what I've found to be normal
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 05-25-2013, 09:14 AM
Gaius's Avatar
Quoted: 50 Post(s)
X2. Mine does this also. If it's below spec PSI, run 'er.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #4 of 5 Old 05-25-2013, 09:40 AM Thread Starter
Thanks Fellas. I feel better already.
post #5 of 5 Old 05-25-2013, 08:00 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
If it starts, run it. If it's too sick to run, it won't start. --> basically an old locomotive mantra.
FWIW, my '95 F250 with 286k runs just as well as my '95 Superduty with only 27k. Both have almost the same amount of blowby. Remember, you've got a 444 cubic inch pump running, so there will be air moving if the crank is turning. I reckon the big thing is oil loss. If you're leak free, but consuming a fair amount of oil, start looking at injector cups, worrying about rings, etc.
So not to worry.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
