Mod's Again ?!?! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-09-2008, 10:06 AM Thread Starter
malcolmhoule's Avatar
Mod's Again ?!?!
Sorry to do this to you yet again but...
1997 4x4 auto 250 ext cab.
No Mods yet- Here is my connundrum, There seems to be an endless supply of mods and I dont know where to start. Mostly I dont know what these will do for my truck, or even what the --ll they are.
What should I do first...-air intake, external oil bypass, That BB thing in the fuel regulator....Gauges???
what will these do for me and what do you think is the best way to start.
(some info)--I just had the truck gone over from start to finish as a diesel shop and the injectors and glow plugs are perfect.
one specific issue- When it is cold (below 10) the oil resevoir drains and does not refill (starts for @ 5 secs - quits ,starts for @ 2 secs - quits, wont start-, look under the hood and there is no oil in the resevoir, refill the resevoir, start enging and rev the motor and it will stay running. If I use an oil pan heater there is no issue.) I am wondering 2 things
1. New oil pump (and if so what kind)
2. different oil.
thanks for all your consideration.
96 F-250 4x4
automatic
220,000
malcolmhoule is offline
post #2 of 12 Old 03-09-2008, 10:32 AM
CoalRollinRoosterCruiser's Avatar
Start with Intake, Exhaust, and Guages. And some of the DIY mods if you want.
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #3 of 12 Old 03-09-2008, 01:41 PM Thread Starter
All right, I will start with an air intake manifold - how will this effect my truck?
Also is there a specific brand - DIY seems to be the concensus from what I have read...
96 F-250 4x4
automatic
220,000
post #4 of 12 Old 03-09-2008, 02:13 PM
DIY Intake is pretty good,
and AFE makes EXCELLENT intakes.
post #5 of 12 Old 03-09-2008, 02:16 PM
International Threat
Marty's Avatar
Familiarize yourself with these threads.
http://www.powerstroke.org/forum/7-3-mod-help/
They have most of the information that you need in order to decide
BTW, this is probably the best way to start...
http://www.powerstroke.org/forum/7-3...ere-first.html
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #6 of 12 Old 03-10-2008, 10:14 AM
Big K's Avatar
2. different oil.
Have you done anything to the Exhuast yet?
THE DOWNPIPE SHOULD BE THE VERY FIRST THING THAT IS REPLACED ON A OBS Truck
I can't say that enough
Kevin "Big K" Neal
President
North Texas Power Stroke Association
972-768-7252
Big K is offline
post #7 of 12 Old 03-10-2008, 04:26 PM Thread Starter
Kevin, thanks for the advise,....why is this the most important mod, and what will it do for me?
96 F-250 4x4
automatic
220,000
post #8 of 12 Old 03-10-2008, 04:41 PM
nic0084's Avatar
The stock downpipe is VERY restrictive, this is it.
Get a 3 inch dowpipe with an entire turbo back exhaust kit or tie it into your stock 3.5" STRAIGHTPIPED. Like mentioned before, do this, DIY or AFE intake, Boost, EGT and Tranny gauges, FPR shim. Then when you want some more power... get you a custom chip from Tony Wildman or DP Tuner with a nice variety of tunes.
97 F350 7.3 Off-Road Build Locked on 42's
08 2500 Cummins
nic0084 is offline
post #9 of 12 Old 03-10-2008, 05:09 PM
nic0084's Avatar
And by the way... a bigger downpipe and straight through exhaust will give you better spool up, lower egts, ALOT more whistle, and help a little with gas mileage.
08 2500 Cummins
nic0084 is offline
post #10 of 12 Old 03-11-2008, 09:23 AM Thread Starter
what the &^%*&^ is spooo up, egts ....is 3 inch big enough
96 F-250 4x4
automatic
220,000
