Airtex or Precision fuel pump? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-25-2013, 05:20 AM Thread Starter
Has anyone used either of these fuel pumps? Which one do you guys prefer? I have a leak and it appears to be coming from the bottom of the fuel pump. I don't want to take everything off, replace the lines, put everything back on and still have a leak, so I'm just going to go ahead and replace the pump while it's torn apart.
Lutz'96 is offline
post #2 of 14 Old 05-25-2013, 06:40 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Putting a mechanical pump back in? Now is the time to convert to an electric fuel pump.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 14 Old 05-25-2013, 08:32 AM Thread Starter
What exactly is the advantage to the electric fuel pump? And what would that cost? Sorry, I'm new to this kind of stuff
Lutz'96 is offline
post #4 of 14 Old 05-25-2013, 10:00 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Consistent fuel psi at sustained higher rpms, and easier to change later down the road
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 14 Old 05-25-2013, 02:06 PM
ol_Blue97's Avatar
no fuel bowl on the engine. gonna cost ya about 500. for a diy kit and 1000 for a pre assembled kit.
FRANK THE TANK
post #6 of 14 Old 12-13-2016, 02:19 PM
BlackOBS_PSD's Avatar
Convert over! Solve all your woes in one swoop.
1997 Ford F-350 XLT 2WD Dually
Just bought it and now modding it.
BlackOBS_PSD is offline
post #7 of 14 Old 12-13-2016, 05:10 PM
Quoted: 69 Post(s)
Yup I have a leak once a year it seems like. E-fuel soon. No more headaches and easier to check IPR and more room to work.
White95f250 is offline
post #8 of 14 Old 12-27-2016, 07:26 PM
Phillipjon's Avatar
Quoted: 76 Post(s)
I have a brand new Bosh SD fuel pump still in the box for sale if interested
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #9 of 14 Old 12-27-2016, 10:40 PM
Boom! One step closer!
post #10 of 14 Old 01-01-2017, 09:29 AM
leojr's Avatar
Quoted: 4 Post(s)
Elsewhere I've read that the stock pump will support stage 2 injectors? Of course a fuel pressure gauge should be used as starving injectors of fuel is harmful to them. But $500 minus the price of a new mechanical fuel pump will go a long ways towards a HPOP.
Am I way off base here? I'm always open to input...
And the original question.....Airtex or Precision?
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
