Intermittent battery light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-23-2013, 05:17 AM Thread Starter
I was towing a 9,000lb trailer or so on Monday. Accelerating to get on the highway I noticed my battery light start flickering on the dash. It was flickering fast for about 2-3min and then went off it did this once or twice more throughout the trip (kept it under 55mph the entire time and it showed normal charging). Hadn't had any problems, then last night driving without a load on the hwy it started doing it again (about 65mph) then went solid then turned back off. I have not had time to check both battery connections to make sure they're tight. My dash gauge shows its charging in the 12-13v range and no sudden jumps or anything. It's still starting fine and the batteries are fairly new. Any thoughts or suggestions?
mathewsz7 is offline
post #2 of 3 Old 05-23-2013, 05:26 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Mine has been doing that for about a year. Had both batteries and alternator tested good. Still starts great and runs good. about 14v when im cruising i have kinda ruled it down to the wires on top of the alternator having an intermittent short but still not positive. Truck runs great so i just ignore it
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 3 Old 05-23-2013, 05:55 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
loose connection on the singe wire on the alternator
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
