Originally Posted by Triflex
Is the fpr the only place you get fuel pressure from? How about the fuel pump? Any pressure from there? I`m 73 and I have to be careful because I don`t work any more. Thanks guys you`ve been very helpful.
No you actually get the pressure from the pump. The Fpr helps regulate system pressure from the fuel return from the fuel gallieries. Thats the two rubber hoses you will see. The regulator will actually help eliminate air from the system also and then it send the excess fuel back to the front of the pump.
