why just 15 psi? - Ford Powerstroke Diesel Forum
Old 03-05-2008, 02:56 PM
why just 15 psi?
Just installed the 2nd fuel pressure gauge. Thought the first one was broken. Wondering why I only get 15 psi at the shreader valve. Truck runs ok.
Old 03-05-2008, 03:01 PM
International Threat
15 psi is VERY low. Actually harmful to your injectors.
Are you sure you have the correct type of gauge?
Old 03-05-2008, 03:02 PM
Desert Shield/Storm Vet
Truck is running with 15psi or is that cranking pressure?
HaHaHa marty we have a habbit of posting at the same time alot
Old 03-05-2008, 03:03 PM
I agree 15 psi is way too low very harmful for injectors. I still think you have a bad FPR especialy scine the housing cracked and you jb welded it
Old 03-05-2008, 03:12 PM
That could be it. I took the little screen out too to clean it up and there is a little plastic ball a little bigger than a bb as I remember in there too and seems like there was a little spring too. If there is mine is missing So I have ball, screen. Should it be ball,spring,screen?
Old 03-05-2008, 03:14 PM
Yes!
Old 03-05-2008, 03:18 PM
Thats at idle after a bb mod.
Old 03-05-2008, 03:19 PM
I ordered one gauge and sent it back, Ordered another from JEG`s by number and it was pictured as a fpg but it only says psi on the gauge, Goes to 100
Old 03-05-2008, 03:22 PM
Yeah you want better then 50 psi at idle
