Rear Drum Brake Problems - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-19-2013, 01:58 PM Thread Starter
So, I spent about a week replacing everything on my rear drum brakes. I replaced everything except for the parking cable. The problem I am having is when I am backing my boat into the water, the drum brakes don't want to hold at all and I am raping the shifter column when I put it back in drive. I am tired of this. I spent almost $300 on my rear brakes and wish I would've just put disc brakes on it. I tightened the shoes tight on the drum before I put them on. I reversed hard. It seemed like it held once but then got adjusted again. Any more recommendations. Anybody trying to sell some disc brakes?
tucker0104 is offline
post #2 of 12 Old 05-20-2013, 12:04 AM
JSchuricht's Avatar
When you back up it will only adjust tighter unless you put them together backwards. Try tightening them down again, if they become loose after backing up, swap the adjuster from right to left.
JSchuricht is offline
post #3 of 12 Old 05-20-2013, 12:44 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
The "star wheel" should ratchet (past the self-adjusting lever) when rotating in the "tightening" direction. If the lever is installed correctly, you will need to manually push it off the start wheel to rotate the star wheel in the "loosening" direction. Cheers!
Patrick Feeley is offline
post #4 of 12 Old 05-20-2013, 03:21 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i have a disc brake conversion and the e brake is worse than the stock drum system though the brakes themselves are excellent
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 12 Old 05-21-2013, 08:52 AM Thread Starter
Can't be much worse than not working at all. Are there any other options besides brakes?
post #6 of 12 Old 05-21-2013, 09:18 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Line locks? They worked great on my floats.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 12 Old 05-21-2013, 09:23 AM
the baconator
Quoted: 141 Post(s)
thought of doing that. i have a stick and when on the boat ramp i put it in gear and shut the truck off if i am getting out
post #8 of 12 Old 05-21-2013, 03:57 PM
Assuming you have new wheel cylinders??
hithebrakes is offline
post #9 of 12 Old 05-22-2013, 11:43 AM Thread Starter
Yes, I have new wheel cylinders.
post #10 of 12 Old 05-23-2013, 01:26 PM
One thing I just thought of
Isnt there an abs power control that distributes braking power front to rear I cant remember the name of it.
