Almost completed my D60 swap - Ford Powerstroke Diesel Forum
post #1 of 50 Old 05-18-2013, 05:32 PM Thread Starter
BR'sCrewCab's Avatar
Thought I was going to be done today. Anyone have any 95 or older caliper brackets they no longer need? Found out the hard way my d60 won't take my existing brakes. Other than that, I am finished.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #2 of 50 Old 05-18-2013, 06:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You need slide pin calipers?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 50 Old 05-18-2013, 06:25 PM Thread Starter
yes, and mounting brackets. The brackets are looking like the hard part to find.
post #4 of 50 Old 05-18-2013, 06:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
As in the slide pins themselves? Help section at autozone or the like should have them, like $5 I think
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 50 Old 05-18-2013, 06:48 PM Thread Starter
Not the slide pins. I need the whole brake assembly. The mounting bracket that attaches to the axle, and the calipers
post #6 of 50 Old 05-18-2013, 07:57 PM
m j
those bits might come with the reman calipers, they did on my rear brakes I discovered after sandblasting and painting the old ones
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #7 of 50 Old 05-18-2013, 09:55 PM
JSchuricht's Avatar
I made the exact same mistake when I did my D60 swap. I knew about the kingpin axles using different brakes but didn't know about the balljoint ones having two different styles. Your best bet is going to be buying calipers, rotors and pads. What you would have to replace is the entire knuckle and if your lucky enough to find a set it will probably be over $500. I bought powerslot cryo rotors, reman calipers and hawlk pads for about $400, the calipers came with pins.
Another option you have is using this as a excuse to install a 10.5 Sterling in the rear and installing super duty knuckles in the front. You would have unitbearings unless you upgraded but you would have better brakes.
JSchuricht is offline
post #8 of 50 Old 05-18-2013, 10:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Honestly I would hit up a junk yard first, and if no good candidates buy new
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 50 Old 05-19-2013, 07:20 AM
Quoted: 80 Post(s)
I will have everything you need off a 94 Dana 50 probably next weekend when I do my Dana 60 swap.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #10 of 50 Old 05-20-2013, 12:11 AM
JSchuricht's Avatar
I don't think that will be everything he needs. He could use your breaks but he wants to keep the new style which means he needs D60 knuckles. D50 TTB knuckles are special.
