coolant in a OBS 7.3 PSD - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-15-2013, 09:17 AM Thread Starter
nohsp4u's Avatar
I have been reading a lot about Green, Gold and ELC coolant. Does any of this apply to my 97 OBS 7.3 PSD?
I ask because i discovered i have the anti christ Green coolant. Any advise is better than what i have now.
Also, FOrd did all maintenance on this rig from PO so ford did this.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 16 Old 05-15-2013, 09:30 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Ford is correct in my opinion. Ethyleenglycol (low silicate/Green) with the diesel additive is what is used in our older Engines. Gold and Orange Rad Fluids are for '02 DuraMaxes / Cummins and '03 6.0 PSDs and new engines (as according to my books at the shop). Something to do with mixed metal blocks and heads. Our all Iron babies get the tried and true.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 16 Old 05-15-2013, 09:47 AM Thread Starter
nohsp4u's Avatar
Sweet so green is good. I just add the F?-15 every 15K and i be good?
Another question, when flushing, how do i flush with distilled water? i mean i have a hose i can run through it, but it ain't distilled water coming out. I can't imagine how to put a bottle of distilled under enough pressure to act like a hose.
Thank you
nohsp4u is offline
post #4 of 16 Old 05-22-2013, 07:44 AM
Question
What happens if you use NEW coolant in an older engine?
CELAYORK is offline
post #5 of 16 Old 05-22-2013, 07:54 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Expensive to switch but once you do I don't think there is anything wrong with the CAT stuff. The others I don't know about. Not willing to try. That and reading the new coolants sold around here it says on the bottle not for diesel before '02. I do know that you cannot run our older stuff in new engines.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #6 of 16 Old 05-22-2013, 10:04 AM
Thumbs up
ok thank you, there are a lot of questions without a reasonable or true answer.
CELAYORK is offline
post #7 of 16 Old 05-22-2013, 01:13 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
bill (alberta 7.3) was running ELC in his 97 OBS, I think it was the CAT coolant. you could ask him
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 16 Old 05-22-2013, 01:18 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
CAT coolant is approved since it is the same coolant from back to 94-ish. It's the non CAT coolants I don't know about but say on the bottles "not for Diesels before '02"
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 16 Old 05-22-2013, 01:20 PM
the baconator
Quoted: 150 Post(s)
didn't know that. and green coolant is the only "approved" coolant for the 7.3 until 2/99 motor build date, don't ask me why
post #10 of 16 Old 05-22-2013, 01:22 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
L99 on did have the compressed graphite (or nodular Iron, or some weird crappy metal) blocks. Maybe that metal does something with the green stuff
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
