Power steering pulley. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-03-2008, 07:22 AM Thread Starter
Anyone know if the PSPulley has a replacable bearing or do I have to buy the whole unit. Got a little wobble. TIA
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #2 of 7 Old 03-03-2008, 07:48 AM
TurboSevenThree's Avatar
I know some power steering pumps you have to get the whole unit, and swap just the pulley because they don't come with one. Is your power steering still working?
Old Truck: 00 F350 XLT DRW: basic first few mods. S&B, 4" straight pipe, gauges, CCV, EBPV and Wastegate line deletes, LED Sills, sweet custom headlights, smoked cab lights, Ventshades, Tint.
Traded in at 196k miles.
"Brand Newish" Truck: 02 Chevy S10 2.2L 5sp. Reg cab 4x2. Badass custom made shifter, foglights, 20% tint, AVS Vent-shades, Stock Intake mods, Electric Fan conversion .
~ 95k miles.
TurboSevenThree is offline
post #3 of 7 Old 03-03-2008, 07:52 AM Thread Starter
Yes, it works real good but the pulley has some wobble to it. It`s more like to pulley is bent than anything else.
Triflex is offline
post #4 of 7 Old 03-03-2008, 07:57 AM
well that's weird. Maybe just bent somehow?
If you're worried about it just get a new pump w/ a core charge and a lifetime warranty. It's not too bad.
But I'm pretty sure you have to get the whole pump, and will have to swap the pulley with a special puller.
~ 95k miles.
post #5 of 7 Old 03-03-2008, 08:22 AM
whh
no bearing in the pulley. It presses on the pump.
WH
96F-350,srw,lb,cc, e4od,3.55 gears 3''dp,tymar intake,99 IC with banks piping,triple pillar gauges,ccv mod, simple tc lock up & ebpv brake,kitty out to play
whh is offline
post #6 of 7 Old 03-03-2008, 08:50 AM Thread Starter
Well, I guess I found the problem. I remember ( I`m 73) Ha. leaving a steel handle hammer that was sitting under the hood somewhere when I drove off and the handle was wedged down toward the pulley. I think it probably bent it. Thanks guys for all the replys. Ford says you can buy the pulley seperate. didn`t know it was pressed on though.
Triflex is offline
post #7 of 7 Old 03-03-2008, 02:36 PM
whh
Don't feel bad I'm only 45 and Saturday I forgot to put my radiator cap back on and lost it. It happens least you have a better excuse than me.
WH
whh is offline
