HELP!!!scanned my 97 psd 6codes came up no ses light on ? - Ford Powerstroke Diesel Forum
Old 03-02-2008, 03:53 PM
hey guys,
been having a small problem with my truck lately, after i start it up and drive around 2-3 miles it will sometimes jerk, like the engine runs out of fuel?
just for a second. when it does it, it also shoots a puff of blue or black smoke out of the exhaust, no engine lights ever kick on,
another thing i noticed was if if was accelerating hard and rev hard it will cut out the same way at 3000 rpm`s , blow a puff of smoke
any help will be grreat!
so i hooked up my edge evo and ran the diognostics test came back with
six codes...
1) P1280- ICP Curcuit out of range,low
2) P0603- Internal control module, keep alive memory,(kam) error
3) P0344- Camshaft position sensor, circut intermittent
4) P0236- Turbo boost sensor, A circut Range/Performance
5) P0470- Exhaust pressure sensor, malfunction
6) P1111- Intake air temp sensor(IAT) , intermittent high voltage
truck seems to run ok the way it is but i`ve only owned it for about three weeks, so maybe it could run better?
truck is a 97 psd w/ 177k 5-speed,
3"dp, 4" straight xhaust, intake , 10k mod, edge evolution,
Old 03-02-2008, 04:01 PM
cam sensor bad
Old 03-02-2008, 04:13 PM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
not particularly the cam sensor... I've replaced mine and scanned it again and got the 603 code also.
Old 03-02-2008, 04:16 PM
International Threat
Do you have a chip? Have your batteries been d/c recently? 10k mod?
1) P1280- ICP Curcuit out of range,low - this can cause a myriad of problems... jerking, no power, sudden power, etc...
check the ICP sensor for oil.
2) P0603- Internal control module, keep alive memory,(kam) error - battery disconnection or chip/program usually makes this code.
3) P0344- Camshaft position sensor, circut intermittent - Possible cam sensor.
4) P0236- Turbo boost sensor, A circut Range/Performance - I'll look more into this but this can also cause some issues you've stated. This is usually associated with a chip/program, but idk if you have one.
5) P0470- Exhaust pressure sensor, malfunction - this means the sensor has detected an error in opening or closeing the valve, or you have a clogged EBP tube.
6) P1111- Intake air temp sensor(IAT) , intermittent high voltage - meanial code - maybe just a short or it got water on it etc... it plugs into the back of the intake box.
Old 03-02-2008, 04:18 PM
I just noticed this part of your post...
What did you do with the Air Intake Temperature Sensor? Make sure it's zip-tied out of the way and not rubbing the wires or something.
Take the 10k out... it's not helping or really doing anything since you have a program. I'll bet you have oil in the sensor. unplug the sensor, remove the 10k and clean that thing good. Any oil in that connection is a REALL problem.
And the Edge is causing your KAM error.
Old 03-02-2008, 04:40 PM
BIG TRUCK, SMALL DRIVER
Nice work Marty, I guess you are a "fart smeller"
Cleaning the EBP is pretty easy, if you need any help let me know, I just did mine a couple days ago.
Old 03-02-2008, 04:45 PM
LOL thanks.
And no need Derrick - I already did a small how-to on it.
EBP Tube Cleaning
Old 03-02-2008, 04:48 PM
i did replace the batts a week ago, i will check the icp sensor for oil and remove the 1ok resistor, i dont think its doin much anyway.
as for the intake air temp sensor i`m not sure , i`ll havto look tomorow, the diy intake was on it when i bought it.
as for as the cps sensor its looks new but its goin in for the cps recall this week... Jason
Old 03-02-2008, 04:50 PM
Sounds like your set. You'll likely end up having the turbo/exhaust pressure codes left after it's all said and done.
I'll get you a picture of the Air Intake Temp sensor.
Old 03-02-2008, 04:51 PM
Here's the DIY intake thread.
DIY Intake
Here is a picture of the sensor.
http://thumb5.webshots.net/t/63/63/2...5PKJlQp_th.jpg
