SRW vs DRW fuel Economy 4.10s - Ford Powerstroke Diesel Forum
post #1 of 22 Old 05-13-2013, 09:32 PM Thread Starter
gabegoforth's Avatar
I am wondering what kind of millage I'm going to get if I go to a DRW flatbed. Ive got a line on a complete swap. I am going to be using this truck for farm related work. Im hoping that you guys are going to tell me the 17s. I currently don't know what kind of milage it gets because its a project. It was owned by a logger that abused it a little cosmetically. I would also like to know what your getting in your SRW with 4.10. My plans included 4" stacks and a TS chip.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 22 Old 05-13-2013, 10:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I get 15.75 in my dually 2wd 4.10's LS bone stock, in my f250 crew cab srw I get 17 city 20 hwy on summer fuel and 17 hwy winter fuel, it's has tunes, intake, full exhaust and 305/55/20's both have 4.10's and LS
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 22 Old 05-14-2013, 04:10 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I get around 15 in both my single wheels with 4.10s I had a dually same gears a cummins though that got 15 as well
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 22 Old 05-14-2013, 06:42 AM Thread Starter
Ok so it sounds like close to the same. A friend is trying to talk me out of going to a flatbed, but I'm wanting to do it anyways. Whats funny though is that my 96 with a lift kit gets 15 too.
post #5 of 22 Old 05-14-2013, 08:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
yes but did you calibrate your speedo? you hand calculations may be off a bit lol, and im not a fan of the flat bed, but my dad has one, and 3.55 gears, somehow his tanks are bigger and he goes much father and has much better economy at higher speeds than I do
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 22 Old 05-14-2013, 07:15 PM
rolsmojave3's Avatar
I have a SRW with 4.10s. I get anywhere from 13.9 to 22mpg depending on how/where I'm driving. I'm also thinking of a flatbed, I doubt mileage would change much.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #7 of 22 Old 07-14-2013, 06:24 AM
I have a 2WD dually CCLB 4.10s E4OD, and I get as high as 19, usually between 17 or 18, and in the 9-11 range when towing my 10k car trailer. I has an intake, exhaust, and a Chip tuned by Cary.
SuperHatch is offline
post #8 of 22 Old 07-14-2013, 06:39 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
My truck(CCSB, 4.10 5speed) as a single wheel STOCK got 16mpg on the highway
Added 285s......16mpg
added 5" of lift and 315s......16mpg
Converted it to a dually.......16mpg
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #9 of 22 Old 07-14-2013, 09:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Sounds like you just can't get better brad
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 22 Old 07-14-2013, 10:58 AM Thread Starter
First I used a GPS to figure the % that my speedo was off. Turns out it was 13.33% off. So my math is OD*1.(% off)=Miles Traveled/gallons to top off. The way I estimated the % is that my Speedo reads 52 when the GPS reads 60(And the GPS I was using is my Garmin Montana 600 that has a 3ft accuracy) So I divide 52 by 60 which gives me .866666 that I then subtract from 1.0 which gives me 13.33%. The reason I multiply the OD distance by 1.1333 is so I don't have to comeback and add if anybody doesn't get that.
