Compound turbo OBS???? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 05-13-2013, 06:16 PM Thread Starter
USMC2001PSD7.3's Avatar
Quoted: 15 Post(s)
Garage
Not too sure what to think about this.........kinda cool or crazy?
USMC2001PSD7.3 is offline
post #2 of 27 Old 05-13-2013, 06:37 PM
jesilvas's Avatar
Quoted: 3 Post(s)
If you're gonna do it, why not just do it right instead of adding one way back there. Dumb I think.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 27 Old 05-13-2013, 07:28 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 18 Post(s)
Feedback Score: 12 reviews
Retarded!!! It's open to the elements, it can get damaged easily, the piping is way to visible and susceptible to getting damaged easily... The list goes on.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #4 of 27 Old 05-13-2013, 07:33 PM Thread Starter
Quoted: 15 Post(s)
Garage
That's what I was thinking. Plus wouldn't the second turbo being so far from the first create more lag and kinda negate the whole compounds concept??
post #5 of 27 Old 05-13-2013, 07:38 PM
mts678's Avatar
Quoted: 18 Post(s)
I'm no turbo expert on that subject, but that seems to make sense.
2017 f250 platinum
mts678 is offline
post #6 of 27 Old 05-13-2013, 07:57 PM
svranger25's Avatar
Wow, really too many problems to list. Pressure drop between the turbo has to be awful, the length of pipe separating them cools the exhaust gas way too much, there goes efficiency, then what has been said, exposed to elements, the amount of lag that that stupid long intake pipe has will create SO much lag, my 2 cents
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #7 of 27 Old 05-13-2013, 09:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Neat idea terrible set up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 27 Old 05-14-2013, 11:07 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Leaks oil BAD! Also no expert on multi-turbo set-ups but isn't the large turbo supposed to be on the engine with the small turbo remote???
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #9 of 27 Old 05-15-2013, 06:48 AM
superduty4x4's Avatar
The big turbo is most often the atmosphere charger, the smaller one the high pressure turbo. Exhaust from the motor feeds the small turbo, the exhaust from the small turbo connects to the atmosphere turbo, air from the large turbo feeds the small turbo. That's my understanding of how most compounds are set up.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #10 of 27 Old 05-15-2013, 07:39 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
You know more then I. To push this farther, if a housing is flow benched and proven to only move so much air than putting the smaller turbo on either end how do you have more air than what the smallest turbo can flow through it?
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
