Should overdrive be off for towing? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-13-2013, 12:32 PM Thread Starter
I remember reading somewhere that overdrive should be turned off when hauling heavy loads. If this is true what constitutes a heavy load? I have a 2,000lb boat or so and never mess with it but I am going to be pulling a 6,000lb tractor about 100 miles both hwy and city at the end of the week
Also, I have no chip yet, all stock e40d
mathewsz7 is offline
post #2 of 12 Old 05-13-2013, 01:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Turn the od off when going up hill, if your truck is lugging uphill and not getting it anymore, your egt's are probably sky rocketing, and boost is really low, get rpms up builds boost and drops egt
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 05-13-2013, 05:55 PM
svranger25's Avatar
Is this the same thinking, (OD off up hill or lugging), for a 12000 pound load?
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #4 of 12 Old 05-14-2013, 10:12 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Pros and cons of both. With the OD on you lug the engine creating higher EGTs. With it off your tranny's TC heats the trans oil fast. I haul a 12,000+ trailer and leave the OD on unless I need to take it out. Then, my chip is designed for me hauling so I'm cheating there.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 12 Old 05-24-2013, 07:53 AM
Quoted: 4 Post(s)
My overdrive is always on while towing my 27-foot travel trailer unless and until
1. It starts frequently "hunting" for a lower gear because of hilly conditions
2. It starts showng EGTs above 1100F or so because I'm climbing.
Airstreamer67 is offline
post #6 of 12 Old 05-24-2013, 12:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
^^ this should be exactly what everyone should do with their auto's
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 12 Old 05-24-2013, 10:03 PM
Red '97's Avatar
i thought it was bad for the tranny to try and put it under heavy load with a lugged engine in overdrive? cant that wear it out faster? i just dont accelerate in overdrive or go up hills with it when i tow, turn it back on when im cruising. i also turn it off in town with heavy traffic so the tranny doesnt go between 3rd and overdrive more than it needs to
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #8 of 12 Old 05-25-2013, 09:08 AM
Gaius's Avatar
Quoted: 50 Post(s)
The E4OD can be towed in OD for as long as you want. I only turn it off when I want to stay in higher RPMs or when it startes to hunt.
The Dodges have a problem with oil pump flow at too low of RPM when in OD. Your Ford is fine.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #9 of 12 Old 05-25-2013, 09:13 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
2nd.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 12 Old 05-26-2013, 05:39 AM
Quoted: 2 Post(s)
depending on what gears u have (3.55) leaving it off might be better off i tow an 10K race trailer and just leave it off egts stay alot lower and seems to get better fuel mileage running 65-68 ish down interstate
97 f250 4x4 ccsb
auto
typical exhaust /6637 intake/ chip
add a leaf leveling front
otherwise mostly stock
joshh77 is offline
